Laptop acer es1-571 no charging
  • infoplus
    • Aug 2017
    • 83
    • ALGERIA
    Hello
    Ihave laptop Acer ES1-571 Not charging any more
    Please help me
    Charging Circuit HPA02224RGRR-1-GP
    thes is all voltage from charging circuit
    ACP & ACN & VCC
    19.22V
    ACDET
    2.6V
    CMPOUT & CMPIN
    0.20V
    SCL & SDA
    3.4V
    ILIM
    3.36V
    BM#
    3.38V
    ACOK#
    0V
    IOUT
    0.033V
    SRN & SRP
    2.71V
    LODRV
    0V
    PHASE
    2.71V
    HIDRV
    2.71V
    REG
    6.05V
    BTST
    5.93V
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Laptop acer es1-571 no charging
    Lodrv and Hidrv reading doesnt seems good. Check Low and High side fets
    • infoplus
      • Aug 2017
      • 83
      • ALGERIA
      Thank you sir for you answer...
      What you mean sur i dont understand
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        PU4404 is High Side and PU4405 is low side fet. I asked you to check them. Specially notice the voltage on pin4(Gate) of both the fets. I hope you understand now.
        • sellit
          • Jun 2017
          • 105
          • Latvia
          Got the same problem, same model Acer Aspire ES1-571 DOMINO_BH MB 15300-1
          Replaced from donor MB PU4403, PU4402, PU4404, PU4405, PQ4406, PQ4401 no changes. Laptop works fine from charger and from battery, but not charging. Blinking orange light. Original battery not working - locked, tested with two new (known good) batteries, Not charging. Please any advice.
          My measurements:
          Charger BQ24737 PU4403
          Charger+Battery| Battery | Charger only
          1 ACN 19.5 | 14.94 | 19.50
          2 ACP 19.5 | 14.94 | 19.50
          3 CMPOUT 0.01 | 0.22 | 0.00
          4 CMPIN 0.06 | 0.00 | 0.06
          5 ACOK# 0.00 | 3.33 | 0.00
          6 ACDET 2.65 | 0.03 | 2.65
          7 IOUT 0.10 | 0.00 | 0.10
          8 SDA 3.35 | 3.35 | 3.36
          9 SCL 3.35 | 3.35 | 3.36
          10 ILIM 3.33 | 3.33 | 3.33
          11 BM# 3.36 | 3.36 | 3.35
          12 SRN 15.13 | 14.90 | 3.44
          13 SRP 15.13 | 14.90 | 3.45
          14 GND 0.00 | 0.00 | 0.00
          15 LODRV 0.00 | 0.00 | 0.00
          16 REG 6.07 | 0.23 | 6.07
          17 BTST 14.84 | 14.60 | 5.96
          18 HIDRV 15.12 | 14.89 | 3.44
          19 PHASE 15.12 | 14.89 | 3.46
          20 VCC 19.49 | 0.26 | 19.49
          Battery conector BTY1
          Charger+Battery |Battery | Charger only
          1 BT+ 15.12 | 14.90 | 3.44
          2 BT+ 15.12 | 14.90 | 3.44
          3 BAT_G 0.00 Goes to GND(battery present pin)
          4 BAT_IN#_1 0.3 | 0.30 | 3.33
          5 BATA_SCL_1 3.35|3.35 | 3.36
          6 BATA_SDA_1 3.35|3.35 | 3.36
          7 GND 0.00
          8 GND 0.00
          • sellit
            • Jun 2017
            • 105
            • Latvia
            Anyone can help, what to check next?
            • Wang Tingting
              Acer Nitro 5 AN515-57-536Q not charging
              by Wang Tingting
              I am trying to fix a Acer Nitro 5 AN515-57-536Q not charging issue, the laptop can boot from battery, adaptor or both. The battery LED is solid orange, but it doesn’t charge. The battery report from win11 looks normal, the acer care
              report is also good for battery.
              Following https://www.badcaps.net/forum/troubl...arging-circuit,
              • DCIN/VCC: 19.1
              • ACIN/ACDET: 3v
              • REGN/VDD: 6v
              • CMSRC : 19v
              • ACOK: 3.3v
              • ACDRV: it is 19v, not 25V(when charging, the ACDRV
              09-10-2025, 01:46 PM
            • abrahim110
              [Help Needed] Acer Aspire 5 A517-52G – Removed Onboard RAM, Now Working But Battery Not Charging
              by abrahim110
              🧵 [Help] Acer Aspire 5 A517-52G – Onboard RAM Removed, BIOS Mod Done, Battery Not Charging
              I have an Acer Aspire 5 A517-52G-53NB laptop.
              The onboard (soldered) RAM was faulty, so I physically removed the chip.
              I also successfully modified the BIOS using the SPD Removal Tool – the laptop now boots fine and works with an 8 GB DDR4 SO-DIMM installed.
              ✅ System status:
              • BIOS mod is done (SPD removed)
              • Laptop boots to Windows normally
              • RAM is detected and stable
              ❌ Problem:
              The battery is not charging:
              • Power adapter
              08-06-2025, 06:15 AM
            • CPUFiddler
              Acer Nitro 5 AN515-45 not charging
              by CPUFiddler
              Hi there. I am trying to repair an Acer Nitro 5 AN515-45 and it's giving me some trouble. I have access to SMD rework station, variable power supply, digital oscilloscope, thermal camera, multimeter, stereo microscope.
              This laptop will boot and run from the power brick and/or the internal battery, but it will not charge the battery. NirSoft BattInfo tells me the charge/discharge currents, so I'm confident in saying that it's not charging. In addition, there's no increase in voltage at the battery connector when the laptop thinks it's charging, not even a few millivolts.
              I've downloaded...
              03-19-2025, 07:44 AM
            • titomno2
              Acer A315-41G similar to AN515-42, AC OK Battery OK but not charging
              by titomno2
              Hi guys,
              I currently trying to figure out why the laptop of my friend did not charge.
              It is a Acer AN515-42 (Ryzen 5 2500U), I manage to make it works on AC and battery but no charging.
              At first it was not working on Battery, I discovered that PQ201 was knocked off and replace it => work on battery precharged on another computer.
              I also checked the small resistors between PQ312 and PQ201 and even if they are ugly values are OK.
              My issue, when I plug the charger computer off, it drains 0.25A during few seconds with amber light on (charging) then amber light blinks...
              06-11-2024, 11:52 AM
            • titomno2
              Acer Nitro AN515-42 Not Charging
              by titomno2
              Hi guys,
              06-11-2024, 02:54 AM
