Dell Inspiron LA-D801P Motherboard completely dead
  • Andreasbest
    • Aug 2014
    • 1171
    • Hellas ( Greece )
    Hello.
    Today i received a Dell Inspiron with LA-D801P motherboard.
    Customer's son spill some orange juice on it from the bottom ventilation holes and laptop completely died.
    I clean up everything with Isopropelene Alcohol but still completely dead, no power, no leds.
    I receive voltage at the adaptor input in board and that's all.
    Any help appreciated, schematic attached. LINK to schematic - https://www.badcaps.net/forum/troubl...74#post1242174
    Thank you in advance!!!
    • 20962
    Re: Dell Inspiron LA-D801P Motherboard completely dead
    Check the ALW (always on) power rails , and check for corrosion under a microscope
    • Andreasbest
      • Aug 2014
      • 1171
      • Hellas ( Greece )
      No corrosion at all, checked it.
      What is the ALW power trails?
        • 20962
        Test the voltage on pin 2 of PL1, pin 1 of PL2 , Pin 1 and 4 of PR703 , Pin 9 and 19 of PU102
        • Mazorca
          • Jan 2017
          • 463
          Also check voltage at pin 5 of PQ740 N-type Mosfet, should be Vin-19.5v for dell. Same Mosfet, pin 1, should be same voltage if conducting. Same Mosfet, pin 4, should be high, around 32v.
          • Andreasbest
            • Aug 2014
            • 1171
            • Hellas ( Greece )
            PL1 has 19v in both pins, PL2 no voltage at all.
            PU102 is 0v at pin9 and 5v at pin 19
            PR703 is not present (check picture top right)
            PQ740 is 19v in pin1, pin4 24.7v, pin5 19v.
              • 20962
              Ok, next test voltage on PU100 pins 2,11,12,17,19
              • Andreasbest
                • Aug 2014
                • 1171
                • Hellas ( Greece )
                PU100 :
                pin2 19.6v
                pin11 4.5v
                pin12 2.3v
                pin17 3.3v
                pin19 0v
                  • 20962
                  Ok, so you`re missing +3VALWP , next,with no power to the board test PR121 if its on the board, it should be 0ohms and/or check for short to gnd pin 19 of PU100
                  • Andreasbest
                    • Aug 2014
                    • 1171
                    • Hellas ( Greece )
                    Didn't manage to find PR121 but pin19 has a shortcircuit (0.004Ω) with ground
                      • 20962
                      Ok , so it might be PU100 that needs replacing, or some other part on the +3VALWP rail. Take off 1 at a time PC106 ,PC107 ,PC108 , and PC109 .check for short after removing each ,and put back on if the short is still there. If its still short after checking those remove PU100 and check short on pin 19 again, if its gone replace PU100 .
                      • Andreasbest
                        • Aug 2014
                        • 1171
                        • Hellas ( Greece )
                        Since i don't have boardview i'm not sure what smd are pc106,pc107,pc108,pc109.
                        Do you think they are these 4 smd bottom right of the PL100?
                          • 20962
                          In this case, yes it will be those 4 big caps to the right of PL100.I can see some crap in between the caps.Put some liquid flux around those caps and heat that area up and clean it up with a brush. Test if the short has gone, if not you have a choice, take off PU100 first or the 4 caps,the caps are all the same value so can`t mix them up.
                          • dellxps15
                            • Feb 2014
                            • 1588
                            • italy
                            remove pjp102 solder with desolder wick and see if 3.3 volt comes to pl100
                            • Andreasbest
                              • Aug 2014
                              • 1171
                              • Hellas ( Greece )
                              Removed all capacitors and PU100 but shortcircuit is still there.
                              Removed PJP102 (with ic and 4 caps off) and shortcircuit gone.
                              • dellxps15
                                • Feb 2014
                                • 1588
                                • italy
                                put ic and caps back in plase and see if on pl100 u have 3.3 volts (all with pjp102 still desoldered)
                                  • 20962
                                  Ah i missed out pjp102,so the short is on +3VALW ,its going to be a difficult repair, unless you can find any obvious damage to any of the parts on that rail.
                                  Check IC`s for any burns or damage on the pins UA1,UZ3,PU703,UE1 and check the CMOS battery area .
                                  • Andreasbest
                                    • Aug 2014
                                    • 1171
                                    • Hellas ( Greece )
                                    Put back everything in place.
                                    As i said without jumper the shortcircuit is gone but still no voltage at PIN19.
                                    • dellxps15
                                      • Feb 2014
                                      • 1588
                                      • italy
                                      page 4 of schematic, followind 3.3 volt line , check following pjp point to track where the short is.
                                      try remove pjp501... still short on pjp102 +3VALW side ?
                                      remove pjp801, then jp5, then jp9.
                                      wich one remove the short ?
                                        • 20962
                                        @Dellxps15 ,do you think pin 12 of PU100 is low 2.3v
                                          DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:36 PM
                                          DELL Inspiron 5680 Inspiron 5000 i5-8400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:30 PM
                                          DELL Inspiron 3668 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3668 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3668 boardview and Inspiron 3668 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:28 PM
                                          DELL Inspiron 5680 Inspiron 5000 i3-8100 Specification for Upgrade or Repair
