Lenovo Yoga 910 Charging Problem
  • BlueMidnight
    replied
    Re: Lenovo Yoga 910 Charging Problem
    Ah well, you can't win them all I suppose. You're welcome
  • mgrharry
    replied
    Sadly I ran out of time on this repair and the customer decided to just purchase a new laptop. A few last notes: when I retested with the battery connected the power adapter did output 19.5v, 5v was only with no battery connected.
    Thanks for all your help. I suspect given enough time it would have been solvable...
  • BlueMidnight
    replied
    It's really hard to explain all the weird readings you're getting with just a bad charger. It's a good idea to at least start by assuming there is just a single bad component. And right now the leading possibility for a single component that could cause all the strange readings is the Intersil chip itself. But that assumes that the readings are accurate. So we'll know after you get a chance to measure them again.
    If the readings remain the same, then the simplest explanation is that PU4 has internal shorts that are sending the supply voltage out to pins where it doesn't belong (e.g. the VBAT and ACIN pins). Of course, having multiple bad components isn't impossible, but that's a bit less likely.
  • mgrharry
    replied
    Hooking up one of these USB C power meters I get the following readings which are consistent with the readings I got off the Intersil chip.
    When I try the universal USB C charger I can't get any reading of the power meter, it just loops.
    Maybe it is just a defective charger? And the system is not compatible with this particular generic USB C power adapter?
    BTW, the measurements for the Intersil chip were done with only the power adapter connected, no battery. I double check the readings when I get a chance.
  • BlueMidnight
    replied
    There are a few strange things about those readings:
    - The AC adapter is outputting 5V instead of 20V. Negotiation of the power up to 20V is handled by a chip other than PU4. Unfortunately, I have no idea which one or when this board is designed to ask for more power. Perhaps when ACOK gets asserted. Which brings me to...
    - ACOK (pin 24) = 0V. So PU4 is saying that it has not detected proper AC adapter input voltage. Proper voltage is defined as greater than 3.8V AC adapter voltage, and greater than 0.8V on ACIN (pin 19). ACOK is supposed to be asserted after ASGATE goes to 0V, but ACOK is remaining at 0V for some reason
    - ACIN is 4.95V. This is strange because you measured the input as 5.08V. ACIN should be a fraction of that because it is on a resistor divider. In fact, if it truly is 4.95V when the input is 5.08V, then at 20V ACIN would be over 19V and fry the chip.
    - The voltage on VBAT (pin 31) and BATGONE (pin 25) indicate that a battery was connected when you took the readings. But a battery voltage of 4.15V would be a totally dead battery (just over 2V per cell).
    Those are the biggest of the things I see so far. It might just be because the readings are jumping around though. So the first thing to do is to double check the readings on the pins I mentioned. If they remain the same, then that will give us a direction to go.
    I copied your readings onto the reference design in the ISL9237 datasheet to do my analysis, so I've gone ahead and attached that page here. The design of the actual board should be quite similar to the reference design.
  • mgrharry
    replied
    Originally posted by BlueMidnight
    Ah okay, so it's an Intersil ISL9237HRZ. And the datasheet confirms a suspicion I had about PQ19 and PQ20. They can be used to boost voltage when the input voltage is lower than required. Anyway.. back to your issue..
    You don't want to inject voltage anywhere... much less on the gate pin of one of the FETs. You have no short to ground. You are measuring positive voltage everywhere (even though the readings change from moment to moment). What you do want to do is measure voltage on all pins of PU4. Hopefully this will tell us whether PU4 is acting up, or if it's one of the FETs, etc. This may be made more difficult due to the readings jumping around, however.
    Also, have you tried a different AC adapter or tried this adapter on another notebook? Because that can also be the culprit.
    here are the readings.
  • mgrharry
    replied
    Originally this issue came about due to liquid damage to the DC in board (LIO) which had corrosion that had eaten away some of the trace on the DC in ribbon. A new DC In board and ribbon are installed and they both look clean and appear to have no issues themselves. As far as the power adapter-- I did try with a generic USB C laptop adapter with the same results. Unfortunately I don't have another Lenovo with USB C power to be able to check results with Lenovo adapter but it seems likely that the problem lies elsewhere.
    replied
    Have you closely inspected inside the motherboard DC-in ribbon connector
  • BlueMidnight
    replied
  • mgrharry
    replied
    At this point if I wanted to try using the DC power supply to inject amps to the board to try to identify the defective chip would I place the positive probe on pin 4 of PQ19?
  • mgrharry
    replied
    Here's a pic of PU4
  • BlueMidnight
    replied
    Interesting...
    Okay, so that clears up some things. I've attached drawings of two main types of input/charging circuit.
    In type number 1, the board is powered by either the AC adapter or the battery. In other words, the main power rail will be at AC adapter voltage or at battery voltage. And there is a separate battery charging circuit (a buck regulator) that only sends current to the battery.
    In type number 2, the board is powered by either the battery or the buck regulator. When the AC adapter is connected, its only job is to provide power to the buck regulator. When the buck regulator is functioning, it provides power to the rest of the board as well as power to charge the battery.
    Your board appears to be a modified version of type number 2 and is illustrated in the last drawing.
    PQ8 seems fine, but one of the other FETs in the drawing may be bad. There could also be an issue with the controller chip. I believe that might be PU4 (an Intersil chip located next to your red circle, in the corner of the board). I can't read the markings on the chip in that photo though, so those would be helpful.
  • mgrharry
    replied
    This board works, but has a problem related to the AC adapter input. There is no evidence of a short to ground as yet. No multimeter measurements have even been done. You must do your basic measurements first.
    The battery and AC adapter current sense resistors are a good place to start since they are easy to find and we know what they are for, even without access to a schematic or boardview.
    The current sense resistors are labelled PR53 and PR57, and are indicated in the attached picture.
    Additionally, there is a white fuse on the back side of the power/USB board, near the USB port, labelled PF2001.
    Measure the voltage on all 3 of these points in the following 3 situations:
    - With only the battery connected
    - With only the AC adapter connected
    - With both the battery and the AC adapter connected
    This should tell us which sense resistor is part of which circuit, which power rail the rest of the board uses, whether the AC adapter voltage is successfully negotiated up to 20V via the USB-C port, and how the input and battery FETs are behaving in the different scenarios.
    OK, here's the results:
    BATTERY ONLY:
    PR53: 7.76
    PR57: 0
    PF2001: 0
    BATTERY + AC
    PR53: switches between 7.76 and 8.3 as charging light blinks
    PR57: switches between 19.93, no reading, and 2 as charging light blinks
    PF2001: jumps around between no reading, .4, 2, and 19
    AC ONLY
    PR53: switches between 3.8 and 2.5
    PR57: 4.61
    PF2001: 5.08
  • Stevie2001
    replied
    Originally posted by mgrharry
    This model charges via USB which is on a separate daughter board connected by ribbon to the mainboard. There are photos a few posts above. Here's a close up of the USB C charging port
    Not sure what is max input voltage but set dc to 1v.
    Find out witch pin is plus
  • BlueMidnight
    replied
  • mgrharry
    replied
  • Stevie2001
    replied
    Take picture of adapter wire main ac wire.
    The pins i need to se colour of the wires.
    Normally their is red and black wire coming from adapter to the pcb jack.
    Remove laptop adapter dont need it.
    Not sure what type of dc power supply you have set voltage and amps to 0.
    Short the gnd and red of dc power supply then set amps to 0.40 after that unshort wire.
    Now set 1v.
    Dc power gnd connect to gnd pin of power jack
    Dc power red to red pin jack.
    Dont connect red permenantly yet just quickly touch it and se.
    if the amp dont exceed 0.40 and if it stays on that or below your ok.
    Now once your happy connect red and use finger all over board to find heated part check both sides if you dont feel heat increase amps very slowly dont go above 2amps it may fry the bad part.
  • mgrharry
    replied
    I do have a DC power supply but need some guidance on where on the motherboard I would inject power.
    Here's a close up of PU3
  • Stevie2001
    replied
    Take pic of pu3 ic close
  • Stevie2001
    replied
    With a normal plug you cant do nothing.
    Dc power supply is needed to carry out the repair.
    Dc power has the ability to detect short on motherboards and shows you how much amps current or voltage taking.
    It also injects amps current into the board and the bad component will heat up you can use freezespray at this point or fingers or thermal camera.
    A normal charger has protection and it cannot do this and using freeze spray at this point will not work but works with thermal camera.
    Rather then messing about put it aside till you get a dc power supply
    Lenovo ThinkPad L13 Yoga Gen 2 (Intel) Notebook Yoga Specification for Upgrade or Repair
    This specification for the Lenovo ThinkPad L13 Yoga Gen 2 (Intel) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L13 Yoga Gen 2 (Intel) boardview and L13 Yoga Gen 2 (Intel) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    09-07-2024, 05:20 AM
    Lenovo ThinkPad X1 Yoga Gen 7 Notebook Yoga Specification for Upgrade or Repair
    This specification for the Lenovo ThinkPad X1 Yoga Gen 7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Yoga Gen 7 boardview and X1 Yoga Gen 7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
