hai am a new one ,happy to be here
  • techetronic
    • May 2017
    • 12
    • qatar
    please, help me
    I have MBP dead ,and some times it power on
    it is 820-3115-b motherboard
    in this mb these voltages are ok
    ppbus g3h is 12.32 volt
    pp3v3s5 is 3.29
    pp3v42 g3h is 3.42
    please help me to solve this
    thanks in advance
    thank you
  • techetronic
    • May 2017
    • 12
    • qatar
    Re: hai am a new one ,happy to be here
    hai
      ASUS ROG G512LI-HAPPY Notebook Strix G15 Specification for Upgrade or Repair
      This specification for the ASUS ROG G512LI-HAPPY Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the G512LI-HAPPY boardview and G512LI-HAPPY schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
      09-06-2024, 11:40 PM
    • ugamazing
      820-02918 PPBUS Cycling, Minor Liquid.
      by ugamazing
      Working on an 820-02918 board that had a minor liquid spill, but it was directly to the ISL/U5200. Essentially the entire area had to be replaced due to corrosion. Got it all cleaned up and everything looks good and checks out, but we're hitting a cycling PPBUS issue now. PPBUS_AON cycles quickly from ~9v-12v, indefinitely.
      Knowing this is typically a sign of a possible short on a lower rail, we checked all around and found no obvious damage or shorts. We have VERY LIMITED parts for this model (exactly 1 single U5200 chip), but I suspect it will end up being a continuity issue or...
      02-18-2025, 11:21 AM
    • cheeky2
      Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
      by cheeky2
      For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
      See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
      01-08-2024, 05:56 AM
    • iMuhtaseb
      820-02098 M1 Pro 14" PPBUS partial short
      by iMuhtaseb
      board came with no signs of life whatsoever, taking only 5V.. measured PPBUS and it was partially shorted (I kinda know this is not an easy one when it's a partial short) around 9 ohms in resistance and 0.012 in diode mode.
      Injected 2 volts since 1v was not enough and my initial suspicion was correct it was the haunted TPS62180.. and on board it looked little discolored to my on the visual inspection..
      Removed and replaced successfully now left ports take 20V for 2 seconds then switch to 5v and cycle.. on the right side it does not even power on the amp meter.....
      01-04-2024, 01:53 AM
    • kjchatman
      820-02020 a2338 motherboard has a ppbus short to ground
      by kjchatman
      this machine came to me as DOA and immediately found the issue as a 12v short to ground. Is it okay to inject voltage into that rail or does it have a potential path to the cpu or something?
      08-21-2025, 12:13 PM
