need motorala code
  • banchi99
    • Jul 2015
    • 107
    • U.S.A
    need motorala code
    please this code , save my life SOS.thks..
    regards to all of you Bros.
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: need motorala code
    Here you go:
    XZ 67.0
    WZ 69.3
    XA 71.9
    WA 74.4
    XB 77.0
    WB 79.7
    YZ 82.5
    YA 85.4
    YB 88.5
    ZZ 91.5
    ZA 94.8
    ZB 97.4
    1Z 100.0
    1A 103.5
    1B 107.2
    2Z 110.9
    2A 114.8
    2B 118.8
    3Z 123.0
    3A 127.3
    3B 131.8
    4Z 136.5
    4A 141.3
    4B 146.2
    5Z 151.4
    5A 156.7
    5B 162.2
    6Z 167.9
    6A 173.8
    6B 179.9
    7Z 186.2
    7A 192.8
    M1 203.5
    8Z 206.5
    M2 210.7
    M3 218.1
    M4 225.7
    9Z 229.1
    M5 233.6
    M6 241.8
    M7 250.3
    0Z 254.1
    And if you don't mean Motorola's (in)famous "PL Tone" codes then you will need to be more specific.
    Follow the white rabbit.
      LCD LED TV Service Menu Codes
      TCL LED TV Service Menu Code
      LG LED TV Service Menu Code
      10-31-2024, 03:58 AM
    • Sorrow1
      Intergraph TDZ 2000 mainboard post code 2F/2E
      by Sorrow1
      I try to repair an old Intergraph TDZ 2000 from 1998. It is a dual Pentum II machine based on Intel 440LX chipset. There is a non-removable bios chip named PhoenixBios B1787840. I cannot see any physical damage to the board. All caps look OK.
      It shows no picture and POST stops with code 2F/2E regardless whether or not any graphic card is plugged in. If memory is removed, it stops on previous code 28/17 and stars beeping. I tested both CPUs in another machine and I also use RAM from another machine.
      When I recorded video of POST card and played it in slow...
      01-03-2024, 04:13 AM
    • DynaxSC
      MSI PRO Z690-A DDR4 (MS-7D25) - stuck during boot every second time - debug code 16 & A1
      by DynaxSC
      Hi Folks
      I have an MSI PRO Z690-A DDR4 (MS-7525) which underwent LGA1700 replacement and had a missing resistor in the VRM section. The missing resistor RV170 (49,9Ω) has been resoldered, and I have also replaced a demaged LGA1700 socket.
      Generally the board does boot to Windows, but not always in the first attempt, but after the second attemp to boot the board with Power Button. Also restarting the board from Windows ends up with stuck boot process, but restarting the board again (long push Power Button or switching off and on PSU). Under Windows etherything works
      09-29-2024, 04:27 PM
    • cloo
      Panasonic ZT60 plasma tv with strange behavior and 8 blink code
      by cloo
      I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
      It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
      So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
      After doing a factory reset this problem was gone and the picture was back to...
      01-06-2025, 06:02 AM
    • cdwayne foremost
      hp 10 digit bios code needed
      by cdwayne foremost
      hey good day all ,do you know where i can attain a 10 digit bios code generated for hp envy 15-ep1002na
      my lock code is : 5CD2226530 or photo below.the pc updated then retart without the user setting a bios lock code..
      12-07-2024, 07:49 PM
