820-3437-B No PP3V3_S5 or PP5V_S4RS3
  • Flippers McCoy
    Tinkerer
    • Mar 2018
    • 106
    Hey, everyone!
    I have a board that won't power on. The charging light comes on and turns to orange, but it shows no signs of life. Occasionally, when I reset the SMC or plug it in, I'll hear a shrill whine for a couple seconds. I see no visible damage on the board, save for some corrosion that cleaned up fine (on and around U3210).
    My current issue, however, is that PP3V3 and PP5V_S4RS3 don't exist. This issue seems to stem from PM_SLP_S4_L not existing either, which is one of the rails responsible for enabling U7501, the IC that is responsible for creating both missing power rails.
    I looked around on the schematics, and my best guess is that PM_SLP_S4_L is created in the CPU or PCH(not sure which one), suggesting that the CPU or PCH is bad.
    Would someone be able to give me advice on how to confirm this, and/or explain how I can troubleshoot this?
    Thank you!
    P.S: I've attached a schematic and boardview to help out
  • Flippers McCoy
    Tinkerer
    • Mar 2018
    • 106
    Re: 820-3437-B No PP3V3_S5 or PP5V_S4RS3
    Update: I found this neat Rossmann forum post that is very similar to my issue.
    I get no voltage bursts on L7520 (read with my voltmeter, I don't have an oscilloscope to test with), and U1950 is getting voltage in, but it is not outputting anything through pin 7.
    U1900 is outputting voltage through pin 1, so I think it should be working. I'm not entirely sure of how to properly troubleshoot an RTC chip.
    Hopefully some of that info is helpful!
    • piernov
      • Jan 2016
      • 4439
      • France
      Check SRTCRST#, RTCRST#, RSMRST#, PWRBTN#, and make sure that all the G3H and S5 rails are ok. Also check if you get a spike on PM_SLP_S4_L after plugging in the charger. If you do, check the BIOS, the BIOS resistors and the traces going to the BIOS.
      Check if the liquid hit any other part.
      • Flippers McCoy
        Tinkerer
        • Mar 2018
        • 106
        I don't get a spike on PM_SLP_S4_L when plugging it in, although I'm only able to measure it with my multimeter, I don't have an oscilloscope to test with.
        Here's what I'm reading for G3H and S5 rails, and those things you mentioned going into the CPU (could you briefly explain their significance?)
        PPBUSG3_H=8.6V
        PPBUS_S5_HS_COMPUTING_ISNS=8.6V
        PPBUS_S5_HS_OTHER_ISNS=8.6V
        PPDCIN_G3H_ISOL=18.9V
        PPDCIN_G3H=18.36V
        PP3V42_G3H=3.42V
        PPVRTC_G3H=3.42V
        PP5V_S5=5V
        PP3V3_S5=0V
        SRTCRST#=3.42V
        RTCRST#=3.42V
        RSMRST#=0V
        PM_PWRBTN_L#=0V
        • piernov
          • Jan 2016
          • 4439
          • France
          Ok so the PCH won't be able to work if PP3V3_S5 is missing, sorry I missed that in your first post. Check SMC_PM_G2_EN and S5_PWR_EN.
          RTCRST# is the RTC reset signal, it tells the PCH to enable the RTC (real-time clock) functions. It is the first signal needed by the PCH.
          SRTCRST# is the secondary RTC reset signal, not sure how it is different from RTCRST# but it is needed too.
          Those signals should always be present if there is power somewhere on the board. Battery, AC adapter, or even coin cell on computers that have one.
          RSMRST# is needed for the PCH to initialize and start managing power states. This is needed to go from S5 to S4. On newer platform there is an intermediate power state, deep suspend so this is a bit more confusing.
          PWRBTN# is the power button signal, it goes low then high to tell the PCH to go to a higher power state (powering on or resuming from sleep for example). It needs to be low for a short time after RSMRST# gets high, then go high.
          • Flippers McCoy
            Tinkerer
            • Mar 2018
            • 106
            Ah, thank you for the good description, that makes sense!
            SMC_PM_G2_EN=3.42V
            S5_PWR_EN=3.42V
            • piernov
              • Jan 2016
              • 4439
              • France
              Ok so U7501 should turn on and generate PP3V3_S5 but it doesn't. What is the resistance to ground on L7560?
              • Flippers McCoy
                Tinkerer
                • Mar 2018
                • 106
                ~1 ohm on both sides of L7560, and when I test for continuity to ground it gets continuity on both sides as well.
                I can't believe I didn't realize that it was shorted to ground!
                • Flippers McCoy
                  Tinkerer
                  • Mar 2018
                  • 106
                  I tried injecting 3.2V at 2 amps to PP3V3_S5 and nothing got hot or smoked. Are there any other ways to find the short to ground?
                  Also, would PP3V3_S5 being shorted to ground prevent PM_SLP_S4_L from being created? To me, it seems that there are two problems, PP3V3_S5 is shorted to ground and PM_SLP_S4_L isn't being created
                    • 21948
                    Could it have anything to do with U5590
                    • Flippers McCoy
                      Tinkerer
                      • Mar 2018
                      • 106
                      It looks like U5590 isn't included in this model, there are just bare solder pads where it should be.
                      (if anyone has an explanation for why a component would show up in the schematics but not on a board, I'd love one!)
                      • piernov
                        • Jan 2016
                        • 4439
                        • France
                        If PP3V3_S5 is not present, the PCH will not work. So no PM_SLP_S4_L.
                        You need to figure out why PP3V3_S5 is shorted.
                        If you don't have more than 1ohm to ground on PP3V3_S5, something has to get hot. Or your PSU doesn't deliver enough amperage.
                        • BlueMidnight
                          • Jan 2015
                          • 489
                          Some components are intended only for development and testing. Production boards do not have them.
                          On other schematics, you might see something like "@" or "DY" next to such components. On boards such as this MacBook Air, you will also see things like the "P3V3S5_ISNS:YES" that is written next to U5590. This indicates that those components are populated only on boards manufactured with that option.
                          There is a table on page 2 listing two different versions of the current sensing circuitry on this board. "ISNS:ENG" and "ISNS:PROD". The "PROD" (production) version lacks some current sensing components that the "ENG" (engineering?) board has. You'll find that the table shows "P3V3S5_ISNS:YES" for one and "P3V3S5_ISNS:NO" for the other.
                          There is also a table on page 42 that shows, when the current sensing components are not populated, a 100k ohm resistor is placed where C5595 would otherwise have been.
                          Those little notes next to the components on schematics can be super important sometimes.
                            • 21948
                            Thanks for the detailed explanation.
                            • chris-swe
                              • May 2018
                              • 14
                              • Sweden
                              Just something to check.
                              Look closely under the U1950 on pin 1 (you might have to remove it to be sure), i have had a couple of them where everything looks good but under the chip on pin 1 its burned away and you will never get PM_S0_PGOOD.
                              I guess you checked for corrosion on all the probe points on those rails as well.
                              • Flippers McCoy
                                Tinkerer
                                • Mar 2018
                                • 106
                                When I inject 3.2V at 5.2 amps, it drags down to .66V-.88V and stays at 5.2 amps, would this be enough. It gets warm near where I'm injecting the voltage, but I think that is to be expected. I can't feel it get hot anywhere else, though. Is 5.2 amps enough?
                                Thank you so much for the great explanation! That makes a lot of sense
                                PM_S0_PGOOD is 0V, but ALL_SYS_PWRGD and CPUVR_PGOOD_R are also 0V, so I don't think that U1950 is necessarily the culprit there, it just not being told to let PP3V42_G3H through. Is this a good assumption?
                                • chris-swe
                                  • May 2018
                                  • 14
                                  • Sweden
                                  Yes, 5.2 Amps is good enough, and voltage drop would be normal as well since your psu wont deliver any mor voltage and amps since you limit it.
                                  But its a nice good short
                                  So follow that rail systematic and you will find the short.
                                  Ok, Then you have to check where ALL_SYS_PWRGD is coming from (Q8150). Is that turning on. If not you follow that back and so on..
                                  You also have to do the same for CPUVR_PGOOD_R. Both of them needs to be present for it to close and let PP3V42_G3H pass to the next step witch is out of the chip and then back in at pin 7.
                                  • Flippers McCoy
                                    Tinkerer
                                    • Mar 2018
                                    • 106
                                    How am I supposed to do this? Are you suggesting I test every component on the rail in order to find which one is shorting to ground? I was considering dousing the board in alcohol, then injecting voltage into PP3V3_S5, then seeing if any particular area dried out first due to warming up. Is this a legitimate technique?
                                    I also checked along both ALL_SYS_PWRGD and CPUVR_PGOOD_R, and it looks like they both need S0 power rails to be active in order to be generated? I'm also unsure of why I'm checking these things to begin with, I don't see how they relate to PP3V3_S5 or U7501
                                    • chris-swe
                                      • May 2018
                                      • 14
                                      • Sweden
                                      Yes, Pure Alcohol would do. I use Pure Methanol myself, but just coz i have alot of it.
                                      Yes, investigation is a bitch. You go around and look on the board, and if you see something that look odd you remove it and check if the short is gone. And the area around U5000? looks good?
                                        • 21948
                                        If you remove L7560 and the short is on pin 1 ,check C7562. If the short is still there on pin 2 remove
                                        C7590,C7592,C7572 and C7593 one at a time,check if the short has gone.
                                        • skwarszczow
                                          Macbook Pro A2141 020-01700-A GPU Artifacts then no S5 rails
                                          by skwarszczow
                                          This is my first post on the forum
                                          I recently purchased a MacBook A2141 from a colleague at work, which had issues with the dedicated GPU. The system occasionally displayed artifacts on the screen and sometimes experienced kernel panics related to the GPU. Interestingly, applying pressure to the VRAM module would temporarily resolve the artifact issues, which made me optimistic about the ease of repair.
                                          Board: 020-01700, Config: Intel i7, 512GB SSD, 16GB Ram.
                                          Before completing the purchase, we decided to erase...
                                          03-23-2025, 06:04 PM
                                        • SarcasticOP
                                          General question about MacBook power rails for repair.
                                          by SarcasticOP
                                          I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                                          • PPBUS_G3H (12.6V-12.8V)
                                            • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                                          • PP3V42_G3H (3.42V)
                                            • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                                          • PPVRTC_G3H (3.3V)
                                            • This
                                          12-12-2024, 05:50 PM
                                        • Cemal Odabasioglu
                                          MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                                          by Cemal Odabasioglu
                                          I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                                          Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                                          Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                                          Observations...
                                          01-14-2025, 03:54 PM
                                        • ferah831208
                                          help with AMD Ryzen 5 7535hs power rails
                                          by ferah831208
                                          Hello there, does anyone have info about AMD Ryzen 5 7535hs power rails or an schematics from a compatible CPU?. I have a quanta G3PR from a HP victus laptop, I suspect cpu is damaged but I would like to know what power rail is the one I guess is damaged. There are 4 coils aprox 4.2 ohm to gnd in parallel next to CPU (I guess vcore) ,one coil same size next to those 4 around 0.7ohms to gnd (damaged rail I guess), and other two smaller I guess associated to less current power rails for CPU logic purposes. Anyone have more specific info? I attached picture.
                                          03-09-2025, 01:59 AM
                                        • DrewPhillips
                                          SFX PSU - Need High Current on 3.3V & 5V Rails?
                                          by DrewPhillips
                                          I have an older system which was built in the Windows 7 era and which has developed, I suspect, a power supply problem. The system had the same problem, random crashes, a couple of years ago, which I subsequently remedied with a new power supply.
                                          The power supply which came with the machine is a no-name "Safe Power PE-300". It is SFX form factor and claims a high current capacity: +3.3V @ 22A and 5V @30A (the +12V rail claims a meager 16A). Problem is that SFX supplies (or even ATX supplies for that matter) having high current ratings on the 3.3V and 5V rails seem to be...
                                          02-18-2025, 01:03 PM
