820-3437-B No PP3V3_S5 or PP5V_S4RS3
  • Flippers McCoy
    Tinkerer
    • Mar 2018
    • 106
    Re: 820-3437-B No PP3V3_S5 or PP5V_S4RS3
    Originally posted by chris-swe
    Yes, investigation is a bitch
    Gotcha I checked out the SMC area, and it looks pristine. I'm going to poke around and check all the components on PP3V3_S5 under my microscope and see how it goes. If that doesn't give me enough to go on, I may try out the alcohol method (both for me, and the board, haha). I'll post an update when I've got one
    If anyone has other things I should try definitely let me know! Thanks for all the help, guys
    • chris-swe
      • May 2018
      • 14
      • Sweden
      Yeah, DONT use to much alcohol on the board, Drink most of it
      after you checked the caps SMDFlea told you to check, also check out the caps on the for the S5_PWR_EN. Look on page 59..
      • Flippers McCoy
        Tinkerer
        • Mar 2018
        • 106
        IT'S FIXED!!! I saw some smutz on C3280, so I removed it and the short to ground went away! Installed another cap from a donor board and it booted up just fine. Kernel_task was going crazy until I did a PRAM and SMC reset.
        Thank you all SO MUCH!! I really appreciate it, this is definitely the most complex board level repair I've ever done, and I definitely would not have been able to do it without all of your help
        • chris-swe
          • May 2018
          • 14
          • Sweden
          GOOD for you!!!
          C3280
          BTW
          For the next one. (Yes, there will be more) ;-)
          Dont know what BoardView program you are using. But if you check out Paul Daniels amazing program it will help you a lot.
          Even his free version is way better then tha other old shit out there.
          So, if you now have a short on pp3v3_S5, ctrl+f to search that on the board. then you click on one of the highlighted points. Then you see pp3v3_S5 out to the right in the component spec. Click on that PP3V3_S5 and you will get every singel component name up on the boardview that PP3V3_S5 goes to.
          Start measuring the caps from one side to another, then flip the board and do the same. This way you rule out the caps quite fast.
          If you dont have his program, look it up... PLDaniels dot com
          • Flippers McCoy
            Tinkerer
            • Mar 2018
            • 106
            Oh yeah, I've been using openboardview ever since I first started, and it absolutely lives up to it's reputation! It makes it sooo easy to find everything you need, making boardviews one less complicated enigma for me to figure out!
              • 21955
              Well done, you found the needle in the haystack .
              • skwarszczow
                Macbook Pro A2141 020-01700-A GPU Artifacts then no S5 rails
                by skwarszczow
                This is my first post on the forum
                I recently purchased a MacBook A2141 from a colleague at work, which had issues with the dedicated GPU. The system occasionally displayed artifacts on the screen and sometimes experienced kernel panics related to the GPU. Interestingly, applying pressure to the VRAM module would temporarily resolve the artifact issues, which made me optimistic about the ease of repair.
                Board: 020-01700, Config: Intel i7, 512GB SSD, 16GB Ram.
                Before completing the purchase, we decided to erase...
                03-23-2025, 06:04 PM
              • SarcasticOP
                General question about MacBook power rails for repair.
                by SarcasticOP
                I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                • PPBUS_G3H (12.6V-12.8V)
                  • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                • PP3V42_G3H (3.42V)
                  • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                • PPVRTC_G3H (3.3V)
                  • This
                12-12-2024, 05:50 PM
              • Cemal Odabasioglu
                MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                by Cemal Odabasioglu
                I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                Observations...
                01-14-2025, 03:54 PM
              • ferah831208
                help with AMD Ryzen 5 7535hs power rails
                by ferah831208
                Hello there, does anyone have info about AMD Ryzen 5 7535hs power rails or an schematics from a compatible CPU?. I have a quanta G3PR from a HP victus laptop, I suspect cpu is damaged but I would like to know what power rail is the one I guess is damaged. There are 4 coils aprox 4.2 ohm to gnd in parallel next to CPU (I guess vcore) ,one coil same size next to those 4 around 0.7ohms to gnd (damaged rail I guess), and other two smaller I guess associated to less current power rails for CPU logic purposes. Anyone have more specific info? I attached picture.
                03-09-2025, 01:59 AM
              • DrewPhillips
                SFX PSU - Need High Current on 3.3V & 5V Rails?
                by DrewPhillips
                I have an older system which was built in the Windows 7 era and which has developed, I suspect, a power supply problem. The system had the same problem, random crashes, a couple of years ago, which I subsequently remedied with a new power supply.
                The power supply which came with the machine is a no-name "Safe Power PE-300". It is SFX form factor and claims a high current capacity: +3.3V @ 22A and 5V @30A (the +12V rail claims a meager 16A). Problem is that SFX supplies (or even ATX supplies for that matter) having high current ratings on the 3.3V and 5V rails seem to be...
                02-18-2025, 01:03 PM
