I need to change mac address and serial number
Re: I need to change mac address and serial number
do you have to be logged on as admin or superuser or something ? -
hello
share your bios dump and i will cleare serial number for you and you will programming serial number after .Comment
It seems you get the message " manufacturing mode" in display. If so, then use the same bcu utility to unlock manufacturing mode. The file you get while putting the "getconfigutilty" has somewhere locked/unlocked mentioned in it. You just need to select unlock and then use setconfig command. After that dmi tool will work.
PS: If you are not getting lock /unlock option in bcu tool config file, then use a diffrent version of bcu tool. All version doesnt work on all mobos. So keep that in mindComment
HP ProOne 600 G2.rar
this current bios that i want to modify serial number or manufacturing programming mode turn to unlockComment
by matyxi dont know what im doing I have CH341A programmer and SPI programming cable from chipsetpro.com the curent serial number is FVFWQ1CJHV2F and the MLB number i dont know and the motherboard id is 820-00840-A
Can somebody please help.
I dont know how to uplode the .bin file-
Channel: BIOS Requests ONLY!
by bruce35Lenovo Thinkcentre m73 serial number change
ORIGINAL NOW PC03A3Y0
CHANGE SERIAL NUMBER DTVE2EM04624800B481800
THANKS
IT SAYS CHIP CAPACITY FULL(EZP 2019)
SERIAL NUMBER DOES NOT FIT THE CHARACTER MORE...-
01-04-2023, 02:03 AM -
by meomeo888Hi all!
Does anyone know how to change Serial Number of a SSD?
What a tool can extract firmware from SSD, just Edit Serial number and flash firmware into SSD again.
Thank you all!11-12-2023, 03:32 AM -
Hi all
Been wondering if flashing bios with bios programmer (bin file) also change it's serial number?
If it's so, can i edit the bin file to change it's original serial number?
Thanks before -
by masvmasvHi!
There is a way to change a BIOS serial number for the computer:
HP ProDesk 400 G6 Mini PC ?
Thank you...-
- Loading...
