lenovo yoga 500-14isk 80r5 not charging
  • shuky
    • Dec 2010
    • 49
    hi,
    i have a lenovo yoga 500, i replaced to a new battery but both battery does not charge.
    the laptop can be turn on. in the battery properties it say charging but the percentage is without change and both battery doesn't charge.
    thank you.
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Re: lenovo yoga 500-14isk 80r5 not charging
    measure all pins of the battery connector while the battery is connected and it is charging.
    • shuky
      • Dec 2010
      • 49
      thank you
      can u see ?
      its
      1 0
      2 0
      3 0.001
      4 2.934
      5 2.221
      6 3.28
      7 0
      8 0
      • caspian
        • Oct 2015
        • 1589
        • Laptop
        pin 1 should be between 10v and 12v. it seems the charging circuit is faulty. check all components of the charging circuit according to the schematics.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          btw, pin1 can show low or even zero volt ,if battery is dead or deeply discharged also.
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • jared101
            Lenovo Ideapad 320-15IKA NM-B452 not charging battery
            by jared101
            NM-B452
            Hi guys. I've used the forum a lot but never asked questions before. I had a Lenovo come in that was shorted on the 20V rail. I fixed that and thought my job was done until I realized it wasn't charging the battery. Here is what I've checked so far
            On the BQ24780SRUYR charging ic
            VCC 20V
            SMBUS lines
            SDA 3.3V
            SCL 3.3V
            Current Sensing lines
            ACP/ACN 2.3 ohms
            SRP/SRN 21.2 ohms
            REGEN line 6V
            PHASE .84V with no battery installed(this may be normal)
            08-03-2022, 09:19 PM
          • Julian Bailey
            HP ProBook 445 G8 Battery not charging
            by Julian Bailey
            Hi all
            We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
            The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
            I have gone around the board with a MM and cant find anything
            Windows shows the battery fine,...
            10-11-2024, 10:34 AM
          • mferna14
            Lenovo Carbon X1 Battery not charging
            by mferna14
            Hi, Working on a Lenovo X1 Carbon 1st Gen (Type 3444) Laptop. Came in for battery problems. Upon testing the battery, I noticed that one of the cells is bursted & has to be replaced. Ordered a Brand New battery. Now it works on battery but does not charge at all. I see in Windows 10 it shows the charging sign & AC power connected but stuck on 79%. I did a press-in switch reset at the botton of the laptop, but did not help. Checked the Voltage on the chip BQ24760RSBR, all seem to be fine. Battery voltages are ok 14.4v but on the battery coil L24, when AC is plugged in I only get 1.8V. Then...
            02-24-2023, 05:25 PM
          • piernov
            Laptop battery charging circuit
            by piernov
            1. Some theory
            1.1. Introduction
            Almost every laptop has a charging circuit of some sort, that does a few things:
            • Manages switching between AC adapter and battery power
            • Manages battery charging and generates power rail to charge battery
            There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
            • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
            • Narrow VDC (NVDC)
            Texas instrument has a nice overview of these technologies with some more details at https:...
            11-15-2020, 01:31 PM
