dv7-4000 start up problem.
  • quic307
    • Jun 2015
    • 259
    • Greece
    Hello friends,
    I have a problem with HP dv7-4000. When I start up the MB, the cpu doesn't powered and shut down.
    I have 3v+5v, Bios Ec ok.
    MB - DA0LX6MB6H1 REV H.
    I attached bios+ec and schematic.
    Can anyone helps?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: dv7-4000 start up problem.
    Does it have dedecated graphics like ati or nvidea?? If there then try a mild reflow of graphics chip. have seen a lot of them failing
    • quic307
      • Jun 2015
      • 259
      • Greece
      I have changed the gpu, same issew. I measure all the coils, only CPU 0v and after 2 sec force shutdown.
      • quic307
        • Jun 2015
        • 259
        • Greece
        It was the PU10 - VT358. I reflow it and works ...
        Good TIP !!!!
        • Kwisatz Haderach
          • Aug 2015
          • 15
          • Spain
          Same problem -> Erratic power on: no power or shutdown in one second.
          Same solution -> Reflow don't work. Reballing PU10 and and it works!.
          Thanks for the tip.
          • theone111
            by theone111
            3. Problem: TV shuts down
            07-22-2024, 10:36 AM
          • Zeonalbasta
            Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
            by Zeonalbasta
            i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
            The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
            09-13-2024, 01:17 PM
          • Gibon378
            Problem with stopping audio and video for no reason
            by Gibon378
            PC Specs:
            • CPU: Ryzen 5 1600
            • GPU: GTX 1080 Palit JetStream
            • MOBO: ASRock ab350 PRO4
            • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
            • PSU: XFX 650W (don't remember what model)
            • OS SSD: ADATA SP920
            • OS: Windows 10 21H2
            Problem description:
            Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
            11-19-2022, 09:41 AM
          • perzyk23
            Lenovo T580 - LCD Panel problem - error 0288
            by perzyk23
            Good morning,
            I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
            10-25-2024, 12:42 AM
          • lazaro.089
            Asus Zephyrus M16 / GU603ZW problem
            by lazaro.089
            Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
            CPU: Core i9-12900H
            Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
            Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
            The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
            08-26-2025, 06:33 PM
