Dell Inspiron 3521 not (+3VS) and (+5VS)
  • tibd
    • Oct 2014
    • 189
    • Sweden
    Re: Dell Inspiron 3521 not (+3VS) and (+5VS)
    Originally posted by azhar2006
    thank you tibd
    The 116 pin (KBC) was tested and there are (3.3) volts
    Hadn't noticed this message. The SUSP# is supposed to be generated from KBC when u press power button (turn on stage). If its there even at sleep or shutoff stages then your problem might be somewhere else. may be at KBC itself. By the way, whats the problem with laptop.
    • azhar2006
      • Feb 2018
      • 27
      • iraq
      Thank you my dear
      The problem is the lack of fan rotation, only the glowing hand light, there is no pull of the current, there is only heat on the PCH.
      There are no voltages 1.5
      I had missed in (KBC) not volts at 116
      What is Coz?
      • tibd
        • Oct 2014
        • 189
        • Sweden
        U get 3.3 volts att SUSP# (pin 116) only at power up.
        • azhar2006
          • Feb 2018
          • 27
          • iraq
          So where do you think the imbalance?
          • azhar2006
            • Feb 2018
            • 27
            • iraq
            QZ2 and the rest of the same problem have been replaced. It does not exist for voltages
            • raajkumar
              • Mar 2015
              • 354
              • Srilanka
              #26
              Did you succeed this case ? I am having same issue But i don't have any voltages on KBC pin 116 ( Susp) and i have 1.186v at (QZ7) +3VS and have 0.709V at ( QZ1 ) +5VS line
              • raajkumar
                • Mar 2015
                • 354
                • Srilanka
                #27
                I replaced QZ2 and that problem solved. But now i am hearing 7 Beeps and no display.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  #28
                  Replace PU400
                  • raajkumar
                    • Mar 2015
                    • 354
                    • Srilanka
                    #29
                    Replace PU400
                    I Replaced PU400 Fan works but it restart again and fan not spinning and Low power showing on +3VS line and +5VS Line. I replaced QZ2 again but still same problem i have.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      #30
                      Are you getting lower then the rated voltage on QZ1?? I mean instead of 5v is it showing say 1.5 or 2v?? Same story on QZ7??
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        #31
                        Replace QZ8 nad not QZ2. Vs voltage will be ok. Confirm after trying.
                        PS:QZ8 and QZ9 is same.
                        • raajkumar
                          • Mar 2015
                          • 354
                          • Srilanka
                          #32
                          I just removed PU400. waited for 30 minutes power on the motherboard, The fan spinning +3VS and +5VS also coming. But it beeps 7 times. i think that SY8033 i got from another scrap board also faulty. at this moment i try to switch off by long press of power switch. It won't start fan again. if i leave it for 30 minutes again it works fan. So I guess PU400 need to replaced by a new one.
                          • raajkumar
                            • Mar 2015
                            • 354
                            • Srilanka
                            #33
                            Thanks mcplslg123 for your advice. I replaced PU400 and Qz2. Laptop started display also came. i fixed the laptop and it boot the os. after one hour time i switch on the laptop, fan not spinning and +VS line showing the same as before.
                            • raajkumar
                              • Mar 2015
                              • 354
                              • Srilanka
                              #34
                              If i removed QZ2 and QZ9, the +5VS and +3VS are coming but it is not switch on fan. anyone can help
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                #35
                                did you replaced qz8???
                                • raajkumar
                                  • Mar 2015
                                  • 354
                                  • Srilanka
                                  #36
                                  Yes I replaced with a new one. But the problem still have.
                                  • CeeEee4
                                    • 43
                                    • EU
                                    #37
                                    Did you solve problem? i have similar issue, no +3VS.
                                    • dssence
                                      • Mar 2007
                                      • 31
                                      #38
                                      Sorry but I'm mixing up myself, SUS# is generated by EC at startup. But It's active low , does this mean it has to be logic 0v at startup or 3volts. It's got # to the side meaning it's low. Then on schematic there's SUSP which should be logic high around 3.3volts where is it genrated?
                                      • mcplslg123
                                        • Jun 2015
                                        • 7262
                                        • india
                                        #39
                                        SUSP should be low and SUSP# should be high at 3.3V.
                                        SUSP is very likely generated from SUSp# thru QZ8
                                        • banuka
                                          • Mar 2021
                                          • srilanka
                                          #40
                                          Thanks lot.i have the same problem and after replace the qz2 problem have solved.
                                            DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                                            This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            09-12-2024, 03:36 PM
                                            DELL Inspiron 5680 Inspiron 5000 i5-8400 Specification for Upgrade or Repair
                                            This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            09-12-2024, 03:30 PM
                                            DELL Inspiron 3668 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                            This specification for the DELL Inspiron 3668 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3668 boardview and Inspiron 3668 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            09-12-2024, 03:28 PM
                                            DELL Inspiron 5680 Inspiron 5000 i3-8100 Specification for Upgrade or Repair
