problem in Motherboard (Q5WVH LA-7912P)
  • azhar2006
    • Feb 2018
    • 27
    • iraq
    Hello guys
    I've had a problem with Motherboard (Q5WVH LA-7912P)
    (U22) is at 123 (+ 5VS). On pin 4 there are 11 volts and 5678 (+ 5VALW).
    But . On (U21) there is no volt on pin 4 and there is no (+ 3VS) on 123.
    The R368 has 19 volts on one end. But there is no volt outside of them.
    Please help me
  • tibd
    • Oct 2014
    • 189
    • Sweden
    Re: problem in Motherboard (Q5WVH LA-7912P)
    Did u check R368 resistance might be defective resistor. Other explanation short to ground at C463 that might pull down the voltage and the remaining is defective Q25 since u have SUSP.
    • azhar2006
      • Feb 2018
      • 27
      • iraq
      Thank you my friend
      See this photo
      I've checked out the R368 it's good
      But Q25 Does the head turn upside down when the pins are different?
      • bachir2004
        • Feb 2015
        • 439
        • maroc
        If you are sure there is no short,you can solder a wire from pin4 of u22 (gate) to pin4 of u21 just for test.
        • tibd
          • Oct 2014
          • 189
          • Sweden
          can u provide a better quality or high resolution pic of that section above?
          There is something wrong with those readings, if 19v present at D1 of Q25 but nothing on other side of the resistor then this means u r missing SUSP, but how does the 19v gets there. What voltages do u get on middle pins of Q25
          • azhar2006
            • Feb 2018
            • 27
            • iraq
            thanks tibd
            When I raise (Q25) from the motherboard I get it 3.3vs
            But there is something else I can do if the problem is in (SUSP ) what should I do?
            • tibd
              • Oct 2014
              • 189
              • Sweden
              No need for new pic I got the boardview and it seems right. Will check and get back to you. It seems at least u have +VSB.
              • tibd
                • Oct 2014
                • 189
                • Sweden
                Resolder q25 and remove C463 and report voltage readings.
                Did u get any voltage readings from middle pins of q25
                • azhar2006
                  • Feb 2018
                  • 27
                  • iraq
                  OK tibd I will do it
                  Is it possible to watch this topic?
                  https://www.badcaps.net/forum/showthread.php?t=68748
                  But what is (SUSP )?
                  • tibd
                    • Oct 2014
                    • 189
                    • Sweden
                    Measure the voltages at pin 1 and 6 of Q27. Pin 116 OF KBC, also pin 114 when u press power button.
                    • iT0mT0m
                      Problem with motherboard Gigabyte X570S Aero G - no detect RAM
                      by iT0mT0m
                      I have problem with detection RAM on this motherboard. When I install CPU(Ryzen 5 2600, 5 4500 or 5 5600G) DRAM Led is lighting all the time. I tried reflash various verion of bios using Q-Flash method and that not resolve my problem. I tried reflash bios by SVOD 4 but that not resolve problem too. All voltages is correct and I don't see any low resistance on coils and other elements on motherboard. I tried replace memory to other and nothing. I don't know where is a problem(maybe connections between cpu and rams socket?). Actually I have boardview for this motherboard and I have...
                      12-23-2023, 12:17 PM
                    • Xristakis795
                      GA-P35-S3 gigabyte motherboard problem after upgrade
                      by Xristakis795
                      hi to all
                      I have the above motherboard on which I had windows xp I upgraded it to windows 10 everything went well just when it rebooted and got updates i saw a message for a very short time that windows is trying to fix a problem they found and then the problem was overcome and all is well
                      the computer works normally without any problems on the internet and in everything
                      but I found out unfortunately when I had completely cut off the power supply from the network and I went the next morning and plugged it in to turn it on when it went to boot a black screen and the cpu was working...
                      12-28-2021, 06:24 AM
                    • hopkok
                      Legion 5 PRO, 3 boards, same problem, NM-D562 Rev. 3.0 motherboard
                      by hopkok
                      Hi friends, last week I got 3 same boards for repair (NM-D562 Rev. 3.0), same problem, power button light up, but motherboard wont start.
                      3,3V_alw and 5V_alw, 1,8V_alw and 0,75V_alw presented on all 3 boards, no other voltages. 1,2V missing and if I checked schematic right, I need 1,2V and than can be +3VS and +5VS generated after getting SUSP_N signal from KBC? or vise versa?
                      I checked for low resistance on coils, no low resistance.
                      Anyone with same issue like me?
                      Thanks for any help.
                      05-24-2025, 04:21 AM
                    • Laurimar Rocha
                      Beginner looking for help diagnosing LA k092p motherboard problem
                      by Laurimar Rocha
                      A very old client brought me a recently purchased notebook that suffered a lightning strike and stopped working, as in my region no one does plate repairs, he asked me to help him despite my little experience.
                      Acer Aspire Vero notebook (n20c5)
                      motherboard FH5AT LA k092p
                      The notebook turns on the motherboard LED but does not turn on the fans or even the video or any sign of life beyond that, I tested the power input, the power reaches the battery, I tested some components around the processor, some give 5.7v others give nothing and others are 19v, I haven't found...
                      02-10-2024, 06:48 AM
                    • cihanpc
                      OEM H55 i7 620Lm MOTHERBOARD BIOS PROBLEM
                      by cihanpc
                      OEM h55 i7 620lm motherboard does not display image. I don't know if it is a bios problem. Is the bios normal?...
                      07-03-2024, 08:03 AM
