asus N501J dead
  • kingskie
    • Oct 2014
    • 249
    • indonesia
    asus N501J dead
    i have trouble with dead asus N501J. the problem is from the mosfet A5 GNC 800L04. does anybody know where to buy this mosfet because i cannot find it online or is there any compatible tipe with this mosfet?
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Re: asus N501J dead
    https://www.bukalapak.com/p/komputer...SABEgJzAPD_BwE
    https://www.*****************/detail...nnel-1188.html
    Try with FDMC8884 or AON7410, I prefer replace with same P0903BEA (from nikos or unikc) or with UBIQ QM3024M
    • kingskie
      • Oct 2014
      • 249
      • indonesia
      Re: asus N501J dead
      thank a lot bro...i will try it
      • kingskie
        • Oct 2014
        • 249
        • indonesia
        Re: asus N501J dead
        unfortunately it is still dead..i just found out that there are 2 capacitors burnt.
        does anybody have schematic for this motherboard?
        • AppleLover123
          Asus X712EA 3 volts after the first mosfet
          by AppleLover123
          Hey guys,
          i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
          I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
          Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
          I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
          Now i thought something...
          12-15-2024, 07:49 AM
        • Scotchmist
          Asus GA502D keeps blowing mosfet
          by Scotchmist
          I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
          I have removed the mosfet and can run the laptop no problem
          The MOSFET is FDPC5018SG
          Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
          08-24-2024, 02:23 PM
        • MicroSMD Lab
          by MicroSMD Lab
          I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
          01-10-2024, 06:36 AM
        • someonenotyou
          ASUS G513R - cannot remove MOSFET
          by someonenotyou
          Hi.
          I have a ASUS G513R laptop with shorted MOSFET (MP86959GMW-Z 45A).
          I tried to preheat the board to 200C brom the bottom and with rework station set to 400C I flowed it for about 2min. The MOSFET does not come off.
          Of course, I did not force it, but tried to lift it up with tweezers.
          Is it possible, that these MOSFETs are glues to the board? Or it got welded to the board from the short? It looks intact, no signs of blowing up.
          10-10-2025, 11:05 AM
        • Timp74
          Odd MOSFET only on some ASUS x99/x299/z370 motherboards..
          by Timp74
          Hi All,
          Could anyone comment on the purpose of the MOSFET circled in red in the attached photo of an ASUS ROG X299 Extreme VRM?
          I'm trying to fix an ASUS motherboard(WS x299 SAGE) with a similar VRM where this MOSFET has burnt out along with one of the IR3555m driver chips. From looking at photos of motherboard VRMs on the internet, it seems only some ASUS motherboards have a MOSFET like this. Although I've seen some photos of ASUS z370 boards where it's not populated. The MOSFET is usually a NTMFS4C06N. It has its drain connected to the output of the Vcore VRM, and on...
          08-13-2021, 01:11 PM
