Sony vpcsb cable from power board to mothernboard
  • liquidzorch
    • Oct 2016
    • 134
    • mexico
    Hello. I have a sony vpcsb (mbx-237) here that seems to have a defective flexible cable, the one that goes from the power board to the motherboard. The computer would not turn on, but after moving the flexible cable around it started to work. It only works if the power board is out, and the flexible cable stretched a little.
    I see from the schematic that most of the cables go to Ethernet and other thing I do not need. Does anybody know what are the absolutely necessary lines to power on? I have searched for the cable but can not find it here in Mexico, even online. I will order one from the US, but it will take more than 2 months to arrive.
    PS.After moving this cable around, it does not work at all anymore, when connected I do not get 19v to motherboard, when it is disconnected I do get 19v.
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • jb_Bak
    by jb_Bak
    CN6401
    Pin 01 NC
    Pin 02 NC
    Pin 03 "BL_ON": 0V
    Pin 04 "N/C"
    Pin 05 "STBY 3.3V": 3.5V
    Pin 06 "GND": N/C
    Pin 07 "AC_OFF"...
    09-27-2021, 04:52 PM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • delpiero3
    Sony Vaio SVS MBX-261 board failure
    by delpiero3
    Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
    Nevertheless, let's say, i don't come as a total beginner.
    I have this old laptop, which suit perfectly my needs, with the...
    10-29-2024, 06:16 AM
