Cxa-0425 lcd back light driver datasheet
  • mjtech
    • Aug 2016
    • 7
    • India
    Hi..
    I needed pinout of cxa-0425 back light driver pinout.
    I traced +12v and ground pin but not able to trace pwm and enable pin....pls help
    thanks...
    Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
    This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
    I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
    I am comparing them to a brand new one that I installed
    The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
    I going to let it run for several days before I remount back on the wall next to the...
    09-05-2024, 06:48 PM
  • PNI E.
    tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
    by PNI E.
    hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
    02-20-2025, 08:36 AM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • russpall
    LG 39ln540v - red light flashes twice, no power to LED driver?
    by russpall
    Hi there,
    I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
    The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
    08-27-2024, 01:07 PM
  • 7dalibor7
    Lumenia street light; LED power supply driver
    by 7dalibor7
    Hello, I've got driver module of a LED street light lamp that had an ant colony inside and probably due to some ant organic fluid driver module shorted.
    Fuse is blown, one of the znr varistor is shorted and there is a burnt resistor from which I cant read the value.
    Does anyone by any chance has a schematics for this driver?
    Thank you
    https://lumenia.com/products/street-...as/e-lum-.html...
    02-13-2023, 09:45 AM
