I got a laptop Dell e6440 when ever i connect battery or charger laptop turns on by itself without pressing power button & it does not shutdown, when shutdown it it turns off and then turns on by itself i think its BIOS is curropted can any one help me in this
Plz need help Dell e6440 laptop does not shutdown and starts by itslef
Tags: None
Re: Plz need help laptop does not shutdown and starts by itslef
post the identification number of the motherboard -
Hello friend, I have the same problem, did you manage to solve it? I appreciate if you help me with the solutionComment
by IamPriteshI have two such machines which is having this issue. After shutdown the system starts on its own in a minute. It does not start immediately. It takes around 20-40 seconds before it starts again on its own. This is driving me crazy and not sure where to start ..
Some very important points :
- Laptop does not auto starts after shutdown if adapter is connected.
- It will only auto start after shutdown if the laptop is in BATTERY only mode.
- I have tried replacing batteries with a known
- if I shutdown the laptop with adapter connected and lets say remove the adapter after 5-10
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by manol278Hi. I have problem with dell laptop E6440 val91 la-9934p rev.1.
I turn on the laptop and it turns off instantly. After 5-6 attempts it turns on normally. I saw that it was burnt PU800, CD3301B Power Controller Chip.
If you see in the photo someone tried to do bypass and remove PR831, PR832, PC820, PR838.
I will replace CD3301B. I have the schematic but i dont know what are the characteristics of other componets to replace...
[Mod. Edit]
Schematic -> https://www.badcaps.net/forum/troubl...cs-theory/trou...01-26-2024, 11:50 AM -
by ShobosHi, I bought 6420 XFR that tries to boot but shuts down after about 3 seconds, CPU gets warm, fan starts.
So far I have tested all rails wich are good, BIOS flashed with CH341, 3.3,5, main rail present. multiple ram sticks tested. Sometimes it might stay on for longer like 4-5 seconds but not always, theres no picture whatsoever. Also on some rare occasions the caps lock flashes 1 time by itself.
NOTE: I am using bench power supply not dell charger with ID pin and NO battery present, kinda doubtful this would cause this issue.
Any help is welcome. Thanks !07-29-2025, 03:53 PM -
- Loading...
