asus tablet p01z charging problem
  • svetec
    • Aug 2015
    • 22
    • Macedonia [FYROM]
    Hi, I have problem with asus tablet p01z. Tablet is not charging, it show only red battery when I press power on. I think problem is this component marked with red circle. Can some one tell what is that and how to solve the problem?
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: asus tablet p01z charging problem
    unplug battery and measure... if its below 3.5v recharge with external charger or bench power supply to 3.7v and then connect battery and connect charger
    Im Back... sort of...
    • svetec
      • Aug 2015
      • 22
      • Macedonia [FYROM]
      It`s not the battery, I allredy charged it with external charger. Its strange problem. When I plug in charger it show red battery. When I press power its the same, red battery. I menage to go in recovery and when I reboot from recovery tablet starts but in the battery indicator show ? and 0%.
      • flat-earther
        ASUS X54H laptop thinks it's always charging even with charger unplugged
        by flat-earther
        The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
        Windows also shows ''Plugged in'' when charger is not connected.
        This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
        Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
        If I let battery run out and say it has 3% Windows will...
        06-24-2025, 09:32 AM
      • lazaro.089
        Asus Zephyrus M16 / GU603ZW problem
        by lazaro.089
        Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
        CPU: Core i9-12900H
        Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
        Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
        The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
        08-26-2025, 06:33 PM
      • ahmarzo
        Hp laptop charging problem
        by ahmarzo
        Have hp laptop motherboard part no opp 17 diner skl/kbl 15289-2 with charging problem.the laptop shows plug in charging but percentage doen not increases.the schematic or boardview is not available.
        Charging ic is bq737 with voltages on pin no
        1&2 -19v
        34&5 -0v
        6 -2.56 v
        7- 0v
        8&9 -3.15v
        10 -0v
        11 -0.18v
        12 & 13 -13v
        14&15 -0v
        16 -6v
        17;18&19 -13v
        20 - 19v
        Voltages on battery connector are
        1&2. -13v
        3&4 -3.14 v
        5&6 -0v
        8&9 are ground...
        03-20-2025, 05:13 AM
      • dimis1975
        Macbook A1466 2014 not charging with macsafe 2 charger
        by dimis1975
        I have a macboook air a1466 that stopped charging the battery.
        BAT PINS: with or without ADAPTER IN
        1- GND
        2- GND
        3- GND
        4-0V sense pin
        5-3.42V
        6-3.42V
        7- 8.4V
        8- 8.4V
        9- 8.4V
        AC Adapter plugged in: after a lot of of hours some times start charging
        No BAT Connected- Green to Orange
        AC Adapter plugged in: BAT Connected- no light
        The strange thing, when I tried a mac charger usb-c with usb-c to macsafe 2 adapter works normally and charging.
        Any ideas what’s wrong please?...
        08-05-2025, 03:43 AM
      • Thomasraud
        Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
        by Thomasraud
        i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
        QUOTED
        -It works on charger (without battery connected-only charger)
        -It works on battery (without charger connected-only battery)
        -& it also works when plugged in battery & charger, but it's not charging the battery
        //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
        and..
        QUOTE
        The IC cannot maintain the input current level
        06-28-2022, 06:47 PM
