acer aspire ES1-432 white screen problem
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    #41
    Re: acer aspire ES1-432 white screen problem
    Here you go:
    • String2016
      • Nov 2015
      • 2238
      • philippines
      #42
      @imranromi on the lvds connector pin 5 0v but pin6 have 3.3v
      • imranromi
        • Jan 2015
        • 1288
        • Pakistan
        #43
        Yes pin 5/6 3.3v both pin jump and try.
        • String2016
          • Nov 2015
          • 2238
          • philippines
          #44
          thanks for the response imranromi you mean from the lvds connector pin6 jump to pin5?so that pin5 will have 3.3v?
          • String2016
            • Nov 2015
            • 2238
            • philippines
            #45
            i already tried short pin 5 and pin6 nothing happens still white screen when i shut it down and turns on again it goes black
            • JaroTech
              • Mar 2015
              • 351
              Thanks to meritosari for the schematics, it will help a lot. Thanks also to jiroy for the service guide, it will be helpful with the information.
              Ok, find transistor Q33, it's connected from pin 3 of U2 (525AU) to pin 6 of the transistor. You can try to locate the transistor with continuity.
              When you have found Q33, measure the voltage at the input of pin 5.
              • String2016
                • Nov 2015
                • 2238
                • philippines
                #47
                Thanks for the response jarotech and thanks for the schematic meritorasari and jiroy.update: i checked with continuity form pin 3 of 525au chip,i found the transistor is near cpu area there is continuity on pin 3 on 525au to pin 6.And when i checked the voltage of pin 5 of that transistor 0v and same with pin 6 0v also
                • JaroTech
                  • Mar 2015
                  • 351
                  With the readings you have taken, we know that the 525AU is good and also the transistor Q33. Only the signal PCH_VDDEN is not good. Have you tried flashing the BIOS?
                  • String2016
                    • Nov 2015
                    • 2238
                    • philippines
                    #49
                    No I still not tried flashing bios,because it boots fine and no problem if external display only used
                    • JaroTech
                      • Mar 2015
                      • 351
                      Maybe the gate (pin 5) of transistor Q33 becomes a short circuit to ground after a few seconds.
                      • String2016
                        • Nov 2015
                        • 2238
                        • philippines
                        #51
                        ok i have noticed on that q33 transistor when i shut down laptop for a long time and turn on, it stays good display for 10 minutes then becomes white.so, i test pin 5 and pin 6 before display ok it shows pin 5 1.8v and pin 6 it shows 1.3v and dropped to 1v if it goes white but pin 5 steady at 1.8v.
                        • JaroTech
                          • Mar 2015
                          • 351
                          If the input pin 5 is fixed and the output pin 6 goes down, the transistor is defective.
                          • String2016
                            • Nov 2015
                            • 2238
                            • philippines
                            #53
                            ok should i try to change it?i need to find the same value with this?
                            • JaroTech
                              • Mar 2015
                              • 351
                              Yes, it's a 2N7002DW, try to find it or an equivalent.
                              • String2016
                                • Nov 2015
                                • 2238
                                • philippines
                                #55
                                when i checked the markings on the transistor it has mark 5-n
                                • JaroTech
                                  • Mar 2015
                                  • 351
                                  Sorry, I did not find anything for the 5-n marking code.
                                  • String2016
                                    • Nov 2015
                                    • 2238
                                    • philippines
                                    #57
                                    sorry when i checked again it not 5-n its S-N mark on the transistor i cannot focus the chip because i dont have microscope but i upload the image the one with the red mark is the transistor connected to 525au chip, and has mark S-N same with the two other transistor.
                                    • JaroTech
                                      • Mar 2015
                                      • 351
                                      You can try this, swap this chip with one of the other two, the other two are for the backlight, you will know after if the chip is defective.
                                      • String2016
                                        • Nov 2015
                                        • 2238
                                        • philippines
                                        #59
                                        I did not try to swap instead ill try first reheat the chip for a couple of seconds and try again and now there is 3v on pin 6 of the transistor and on the schematics its showing that pin 6 should have 3v and now the voltage it's not dropping.I test for a couple of minutes to make sure and see if its the same issue,I will update later. thanks again for the response jarotech
                                        • String2016
                                          • Nov 2015
                                          • 2238
                                          • philippines
                                          #60
                                          Update:thank you jarotech for the help I tested now for nearly a hour the issue not came back the display is ok.I checked Q33 pin 6 the voltage 3v is steady and not dropping,but I am worried on Q31 pin 6 for PCH_BRIGHT the voltage only is 2.1v and on the schematics it should be 3v.Is this ok if pin 6 q31 not become 3v?
                                            ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                            This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-12-2024, 03:28 PM
                                            ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                            This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-12-2024, 02:30 PM
                                            ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                            This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            09-06-2024, 05:27 AM
                                            ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                                            This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
