acer aspire ES1-432 white screen problem
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Re: acer aspire ES1-432 white screen problem
    thanks for the response jarotech yes there is a chip on the backside on the lvds connector it shows 525AU and when i used continuity on pin 35 yes its beeping it is connected
    • JaroTech
      • Mar 2015
      • 351
      Is pin 35 connected to pin 1 of this chip?
      • String2016
        • Nov 2015
        • 2238
        • philippines
        yes it is connected pin 35 to pin 1 of the chip
        • JaroTech
          • Mar 2015
          • 351
          Ok, you should have 3V on pins 4 and 6, what do you have on pin 3 and pin 1?
          • String2016
            • Nov 2015
            • 2238
            • philippines
            this chip has five legs only 3 on the other side and 2 on other side.on pin 123 there is 0v but on pin 4 and 5 there is 3.3v
            • JaroTech
              • Mar 2015
              • 351
              I have the datasheet for the G5243A (523Ax), for this chip the enable pin 3 is active-high, if it is 0V, the chip is not activated. But you have a 525AU, I do not have the datasheet for this one, I don't know if pin 3 should be 3.3V.
              • String2016
                • Nov 2015
                • 2238
                • philippines
                #27
                ok thanks for the response jarotech maybe someone can share datasheet and help on this please
                • arisravi
                  • Dec 2014
                  • 20
                  • india
                  #28
                  genenerally input is 3volts and measure voltage at the output.
                  at the time display comes the output will be 3 volts ,it becomes 0 volts if screen trun white
                  if it happens like that,short the input and output of lcd vcc 5pin mosfet.use schematic to identify mosfet
                  • String2016
                    • Nov 2015
                    • 2238
                    • philippines
                    #29
                    thanks for the response arisravi do you mean i have to make a jumper form pin 4 or 5 to pin 3?the problem now is only a second shows good display and then it goes white and for a long time it goes black.i dont have schematic for this model
                    • JaroTech
                      • Mar 2015
                      • 351
                      The schematics for the ES1-432 is Quanta ZQF, you have the schematics on different site, but you have to paid for it. I'm using the schematics for the ES1-431 for reference, it's not the same but you can compare the components.
                      • String2016
                        • Nov 2015
                        • 2238
                        • philippines
                        #31
                        could you share here please and it is not possible to make jumper from pin 4 to pin 3?
                        • JaroTech
                          • Mar 2015
                          • 351
                          This is the schematics for the ES1-431, and the datasheet for the G5243A of the ES1-431. If you make a jumper from the pin 4 to pin 3 for your 525AU chip, you will bypass the function of the PCH_DISP_ON.
                          • String2016
                            • Nov 2015
                            • 2238
                            • philippines
                            #33
                            thanks for the datasheet and schematic.you are right pch_dip_on will be bypass if i make a jumper.i have attached the image of 525au chip on pin 3 there is 1 resistor and it measures 4.22kiloohms could it be this the culprit?
                            • JaroTech
                              • Mar 2015
                              • 351
                              It's hard to say because we do not have the schematics for your ES1-432 and the 525AU.
                              • String2016
                                • Nov 2015
                                • 2238
                                • philippines
                                #35
                                maybe someone can share a schematic for this model please
                                • String2016
                                  • Nov 2015
                                  • 2238
                                  • philippines
                                  #36
                                  anyone please help if you have schematic for this model please share
                                  • JaroTech
                                    • Mar 2015
                                    • 351
                                    I don't think anyone on this site wants to share the schematics for Acer Aspire ES1-432 Quanta ZQF if they have it?
                                    • String2016
                                      • Nov 2015
                                      • 2238
                                      • philippines
                                      #38
                                      still anyone who can share please help
                                      • imranromi
                                        • Jan 2015
                                        • 1290
                                        • Pakistan
                                        #39
                                        Originally posted by String2016
                                        anyone please help
                                        Led connector check pin 5 and 6 (3.3v) have or not?
                                        • jiroy
                                          • Jun 2016
                                          • 2416
                                          • Lebanon
                                          #40
                                          Sorry guys , I have only the service guide for this model :
                                            ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                            This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-12-2024, 03:28 PM
                                            ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                            This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-12-2024, 02:30 PM
                                            ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                            This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            09-06-2024, 05:27 AM
                                            ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                                            This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
