Hi everyone!I need help on this Acer aspire ES1-432 DA0ZQFMB6F0 REV:F.The problem with this display comes on and after a few second it comes white screen,I already tried replace lvds cable and test screen on other motherboard both are ok but when i plugged in the screen with this motherboard it boots fine shows image,but a couple of seconds it shows white screen.Can anyone help me on this please
acer aspire ES1-432 white screen problem
Tags: None
Re: acer aspire ES1-432 white screen problem
I inspect around lvds seems fine no corrosion or hot components,ill tried different screen still the same issue display the after a couple of second goes white againComment
if you turn the laptop on after a long time of being off, how many seconds does it take to go white?
if you shut it down after a white screen and turn it on immediately, how many seconds does it take to go white?Comment
If laptop shutdown for a long time it takes 48 seconds to goes white the a second ok the goes white again.if shut it down immediately and turn on again i takes 16 seconds to goes white again.Comment
it switch twice then goes white then not switching againComment
Now keep track of voltages on the LVDS connector to see which pins have voltage change when the display switches from being OK to being white and report the pin number. Take a lot of care not to make any short on the LVDS connector.Comment
ok thanks for the response ill give update tomorrowComment
ok thanks caspian ill upload image tomorrow and give update on those pins of lvdsComment
thanks for the response on pin 35 0v when white screenComment
I have solved similar issue before and it was due to the LCD_VCC voltage, look for the transistor supplying that voltage and replace it. Or send the board model so that I can help you out with the schematicComment
Thanks for the response board codeA0ZQFMB6F0 REV:F in the image above i have uploaded there is one transistor before the ceramic caps could it be that one?
by rybbyHi,
I have an acer aspire 5 a515-51 that turns on but has a black screen.
This laptop has the same symptoms as https://www.badcaps.net/forum/showth...er+aspire+a515, however mine is a different model Acer Aspire A515-51 (without the 'G'). There is no onboard ram on this laptop.
Description of the problem is the same: I press the power button, the fan spins for a few seconds and then stops, the computer stays on all the time (led blue), the cpu and gpu are lukewarm. If I leave the pc on for a few minutes the fan starts... -
by StukiHi tech-guys,
I have problem with Acer Aspire 3 (A315-41). When I pressing power button, the screen showing me this picture.
Sometimes lcd screen works normally.
Thanks advance.... -
by resistor83hi, i have an acer aspire 5 a515-51g that turns on but has a black screen.
I tried to flash the bios with this https://www.badcaps.net/forum/showpo...8&postcount=30 but the problem is still there
To be precise: I press the power button, the fan spins for a few seconds and then stops, the computer stays on all the time (led blue), the cpu and gpu are lukewarm. If I leave the pc on for a few minutes the fan starts spinning a bit and then shuts down again and the pc stays on all the time.
What could it be?
What measurements can I take?... -
by WardyHi, I have got a Acer Aspire 3 laptop that won't boot properly. I keep getting the below stop codes;
IRQL_NOT_GREATER_OR_EQUAL
PAGE_FAULT_IN_NONPAGED_AREA
'DRIVER IRQL NOT LESS OR EQUAL'
I have tried to install a fresh windows 10 home but it crashes before it can finish it's full install. I have also cleaned the RAM slot. Tried an external drive HDD with windows 10 home installed via USB and still the same issue. Also tried resetting the laptop via windows but still the same thing.
Has anyone got any ideas why this is happening... -
by juntmeakohello, i have acer aspire es1-432-c79f, it is coming on, but the issue is the screen goes blank and sometimes the screen goes black, but the laptop is on, i already tried external monitor but same issue. i already flash the bios, but problem is still there, i already formatted the hard drive but still same thing problem still occur, also when pluggibg the charger the screen goes blank and sometimes goes blank. but i notice that everything works fine in safe mode... anyone suggestion to address this problem? thank you so much...
- Loading...
