dell 3543 on time auto off
  • Sanjeewait
    • Aug 2016
    • 63
    • Sri Lanka
    i have a dell dell 3543 laptop. it connect the power auto on , ran diagnostics & auto off. before no power on
    power on connector 3.3v not cumming it voltage is 0.98 v
    how to fix this error
    help me
  • shouri
    Dell latitude e5490 auto restart
    by shouri
    Hi guys, can someone help me?
    I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
    Board model is dm70 la-f401p rev:1.0 2017-09-20.
    At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
    After a few days test, is seems ok.
    Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
    12-10-2024, 09:27 PM
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • Akhlz001
    by Akhlz001
    09-20-2025, 07:15 PM
  • master3112
    by master3112
    07-29-2025, 01:55 PM
    Dell Thunderbolt Firmware
    by SMDFlea
    Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
    Some models have a choice of 2 different firmwares, it depends on the dell SKU.
    The SKU is in brackets (****)
    EDIT: NVM65...
    01-26-2025, 06:22 AM
