dv6 3120us blank screen f11 f12 red led
  • hienton2
    • Sep 2009
    • 183
    My dv6 3120us ,turn on, has blank screen f11 f12 red led, cap lock sometime on somtimes
    not. no blink,.
    Anybody help Please why f11 is on ? I doubt the gpu is bad?
    Good day Thanks
  • piernov
    • Jan 2016
    • 4436
    • France
    Re: dv6 3120us blank screen f11 f12 red led
    RS880M northbridge, can go bad. Try to mildy heat heat for a couple of minutes at 200°C to see if it comes back to life. Make sure you don't overheat it, and this will only be a very temporary fix, the northbridge will need to be replaced.
    Also I assume you tried with known good ram sticks and cleaned the RAM slots first.
    • hienton2
      • Sep 2009
      • 183
      Thank you Piernov
      I will reflow northbridge and clean ram slot.
      MY question Did my laptop complete booting ? Or on half way ? Only the picture is the problem?
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • Chrissygizmo
        Panasonic TX-48CX350B backlights but white screen , blank screen
        by Chrissygizmo
        Hi all, I’ve got a problem I hope someone can help me fixi.
        I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
        01-11-2025, 03:18 PM
      • dicky96
        HP Elitebook Screen blank - backlights but no image
        by dicky96
        Hi guys
        I'm trying to fix this laptop screen
        Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
        OK so I have the original screen which works but has lines across the bottom quarter of the screen
        I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
        04-28-2021, 07:30 AM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • Kalman27
        Lenovo IdeaPad Slim 5 14IAH8 - Type 83BF OLED Blank screen
        by Kalman27
        We have a Lenovo IdeaPad Slim 5 14IAH8 - Type 83BF for repair. The original issue the OLED screen is blank.
        We have replaced the OLED screen with the exact model, also we replaced the LCD cable, but no luck.
        I think there is something with the motherboard. I don't really have experience with OLED screens so far, so not sure how it should work. I have seen some laptop comes with a separate controller board, but this model does not.
        Also, there is an error in Windows device manager - This device cannot start (Code 10) - Intel(R) Serial IO I2C Host Controller...
        06-17-2025, 05:52 AM
