hp 14 ac005nx no display
  • crowntoy99
    • Oct 2012
    • 267
    • india
    hp 14-ac005nx
    hsb j mv-6
    skittl10-6050a2730001-mb-a01
    lap on but no display old bios is missing
    i fund hp official web site in bios (080BD) lap tun on but 20 second display coming then black screen
    after re flash bios saim issue
    any idea ??
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    Re: hp 14 ac005nx no display
    Try this
    • crowntoy99
      • Oct 2012
      • 267
      • india
      Originally posted by jasko_jacker
      Try this
      thank you
      black screen
      • jasko_jacker
        • Oct 2014
        • 1140
        • italy
        Another bios
        But your model have a discrete or uma motherboard ?
        • crowntoy99
          • Oct 2012
          • 267
          • india
          Another bios
          sorry its also black screen
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Try to measure voltage at led connector when there is display and compare what is missing when display goes black. Sonce display is coming for only 20 seconds, you may need to measure 4-5 pins at one go.
            • crowntoy99
              • Oct 2012
              • 267
              • india
              pin out
              1 . 19v
              2 .19v
              3 . 0.473v
              4 . 3 v
              5 . 0 v ( press power button coming 3.3v then 0v
              6 . 0
              7 3v
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Trace that Pin5 in mb. Some thing is perhaps making the 3v to cut off. You can cut that pin5 cable in the lvds cable and inject 3v from lab psu on that pin and switch on the mb. Observe what happens. In no case 3v from lab psu should go into mb. Be careful. I repeat-You need to give 3v on the cutted pin5 cable of lvds cable so that it reaches screen only.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  pin3 voltage is also suspicious-should be 3.3v
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Most of the inventec mb have 19v on pin1 &2 and 3.3v On pin3/4/5. So i think you need to trace those pins first.
                    • crowntoy99
                      • Oct 2012
                      • 267
                      • india
                      thank you sir
                      i find replays coil now its working
                      • String2016
                        • Nov 2015
                        • 2238
                        • philippines
                        where is the coil located?you mean did you replaced it? can you please explain
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3628
                          • slovakia
                          burn coil in LVDS is mostly fuse behind 19V on LVDS
                          • subroto
                            • Oct 2015
                            • 230
                            • Bangladesh
                            Originally posted by crowntoy99
                            thank you sir
                            Where is the coil?
                            • subroto
                              • Oct 2015
                              • 230
                              • Bangladesh
                              I'm facing the same problem. No picture, no light just display blank out after powering up.
                              No voltage on pin no. 4 and 5 but 3.3v on pin no. 3.
                              What to do now?
                              Mates please help me. Anyone have any idea or schematic of this model?
                              • crowntoy99
                                • Oct 2012
                                • 267
                                • india
                                Originally posted by subroto
                                Where is the coil?
                                bro its processor back said on board
                                • subroto
                                  • Oct 2015
                                  • 230
                                  • Bangladesh
                                  I cant find the coil. Would you please help me to find it out bro?
                                  • subroto
                                    • Oct 2015
                                    • 230
                                    • Bangladesh
                                    Here is the picture of both side of mobo. Please help me to identify the coil.
                                    • crowntoy99
                                      • Oct 2012
                                      • 267
                                      • india
                                      bro
                                      sorry for late
                                      see photo check the inductor
                                      • subroto
                                        • Oct 2015
                                        • 230
                                        • Bangladesh
                                        bro
                                        sorry for late
                                        In my case, inductor shows 0 Ohm that means it shorted and ok. Then what to do? Any idea?
                                        What was in your case?
