OA75794 HDD Motor Controller Chip - info needed
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    Does anyone know where I can find a datasheet for this HDD Controller chip from a Hitachi 1TB sata drive?
    Also where I can buy these chips (UK) or if there is a compatible part number? I think the part number is 0A75794 (see pic)
    I'm pretty sure the motor controller chip has failed on this drive as it gets hot and the drive does not spin up though I can hear the heads moving. Also there is a short circuit to ground from either side of the inductor marked 100 which is near the motor controller.
    Cheers
    Rich
    Follow me on YouTube
    Learn Electronics Repair
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: OA75794 HDD Motor Controller Chip - info needed
    buy donor hdd on ebay or similar
    also if motor had stuck similar syptoms so it could be the motor itself
    Im Back... sort of...
    • dicky96
      Sun Seeker
      • Mar 2017
      • 1825
      • Spain
      OK Thanks, I have seen donor boards (or even supposed working ones) I just wondered if replacing the driver IC is cheaper as it is not so difficult to solder chips of that pin pitch - i've done similar 48 pin packages on LED TV repairs no problem.
      Is it possible to build some sort of test rig using an arduino or similar to spin a HDD motor so you could hear it moving? As there are only 4 connections to the motor that would seem not so difficult to do, it must be a matter of pulsing the pins at the correct phase.
      That would be a rather useful piece of test equipment to prove if a motor is physically stuck or not
      Cheers
      Rich
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        I havent seen that anywhere but you can heat motor with hot air gun and then connect to pc and try while its hot, it should spin for a while
        • FIGURETECH
          • Apr 2022
          • SIERRA LEONE
          EDUCATIVE replies
          • FIGURETECH
            • Apr 2022
            • SIERRA LEONE
            WHAT are the actual voltages on a HDD thanks in advance. I am new in the field I wish to know the basics first. The name of the voltages and where can I read them easily on the board
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • Ardent1
              Lenovo IdeaPad 3 15IIL05 81WE New Blank Chip - help needed
              by Ardent1
              Hello everyone, I have never flashed a bios before and currently find myself needing to flash a new Winbond W25Q128JVSQ chip without the original bios file.. I have a CH341A programmer and have been able to connect the chip to neo-programmer, but that's about as far as my knowledge takes me so far. When i read the chip the data appeared to be all FF for every entry.
              I do not know the history of the motherboard, only that the old chip was removed because it was dead apparently. When the on button is pressed, the laptop on battery alone just shows a solid white light on the side and same on...
              12-18-2024, 02:52 PM
            • BMCappelletti
              Asus Chromebox CN62 - wrong chip put on BIOS reader
              by BMCappelletti
              Long story short:
              - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
              - gave the computer to his son a couple years later
              - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
              - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
              (seems like the story was not that short)
              He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
              01-08-2025, 07:27 PM
            • Troystain
              Help EZP2023+ updated chip database for w25q256jveq?
              by Troystain
              Hello, anyone here have updated ezp2023+ chip database in .dat file format.
              I need to add w25q256jveq chip but I do not know what data should I type.
              I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
              The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
              11-25-2024, 12:53 AM
            • ee91137
              Mac mini M4 (A3238) Ripped Chip - Schematics+BoardView Needed
              by ee91137
              I'm looking for assistance with a Mac mini (M4, 2024), model A3238 (Model MCYT4LL/A), which I recently purchased. The front USB-C ports are not providing power.
              Upon inspection, I've identified that a chip and an adjacent capacitor have been physically ripped off the logic board near the SSD connector.
              Could anyone provide information on the specifications of this missing chip? Additionally, I would greatly appreciate it if anyone has access to the schematics and board view for the Mac mini A3238 logic board.
              Thanks for your help!
              07-13-2025, 11:00 AM
