Toshiba L850-13Q video output problem
  • tsiga
    • Jan 2014
    • 76
    • ott
    I got 2 same of Toshiba, same motherboard number same, same error.
    When i try turning it on, the CPU Fan spin, screen is stay black in HDMI,LVDS.
    Client complained about the software of the dedicated video card.I try heat up Dvga core,but not change.I think, the problem with dvga, but not sure because i have dakar SCH. (not quite same) which chipset and video card are on the same line.
    Tested V.output
    LVDS,HDMI:no output
    VGA:Wierd characters in post screen.Picture
    Schematic from dr-bios/L850
    Laptop modell:L850-13Q
    PN:PSKDNE-006006HU
    SN:5C364014R
    MB:PLF/PLR/CSF/CSR DSC MB rev:2.1
    HW:
    Intel i 2.gen
    Intel SLJ8E
    AMD D.VGA 216-0833000
    I haven't seen before like that....
    Is there any idea for someone?
  • tsiga
    • Jan 2014
    • 76
    • ott
    Re: Toshiba L850-13Q video output problem
    Anyone?
    • Spikeman
      Help on Video Problem on Dell Inspiron 7459
      by Spikeman
      Hi, I'll tell you the story of this PC.
      The PC was repaired because it had a shorted power supply. What happened was that the plastic covering the buffer battery positioned by the manufacturer on the capacitor melted, thus generating a short.
      After the repair, the PC worked, I installed Windows 11 and I may have had some problems with the video drivers, but after a bit of tinkering I think I solved them.
      However, the PC later presented the problem in the video shared very frequently.
      The problem also occurs at startup, in the bios and when using it as a monitor thanks...
      02-27-2024, 10:17 AM
    • FrancescoV
      Onkyo HT-R390 no sound output, video output ok
      by FrancescoV
      Good morning everyone,
      I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
      The firmware reported is the following:
      M:1.00/11107BLP
      D:?.??/????????
      O:1.00/11107AL
      The DSP firmware given the question marks seems corrupt.
      On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
      05-11-2025, 02:59 AM
    • Gibon378
      Problem with stopping audio and video for no reason
      by Gibon378
      PC Specs:
      • CPU: Ryzen 5 1600
      • GPU: GTX 1080 Palit JetStream
      • MOBO: ASRock ab350 PRO4
      • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
      • PSU: XFX 650W (don't remember what model)
      • OS SSD: ADATA SP920
      • OS: Windows 10 21H2
      Problem description:
      Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
      11-19-2022, 09:41 AM
    • zimeyh
      Problem video A1502
      by zimeyh
      Hi guys! I have a problem with macbook pro A1502. This display have a apple video, when launch desktop, this display is off. A connect thunderbolt a monitor, have video and laptop and monitor. Disconnect thunder video power off. Whats problem? 🤦🏻*♂️ thankss
      11-15-2023, 03:19 AM
    • delphi_firebird
      Toshiba Qosmio X755 Charging problem
      by delphi_firebird
      Hello Guys,
      I received Toshiba Qosmio X755 that has a charging problem and I'm stuck trying to figure out the problem.
      - When battery is unplugged i works without any problem.
      - When I plug in the battery after plugging in the charger, it works correctly and the battery is charging.
      - When I plug in the charger after inserting the battery, it stops working. ( voltage dropped and consumed 8A, reaching the maximum capacity of my bench power supply for 5 seconds, and stop working after )
      Can you help me diagnose the problem? I have attached...
      10-16-2023, 03:04 AM
