HP 520 LA-3491P High Side MOSFET Heat Problem
  • Lex-
    • May 2011
    • 18
    1.8v rail shorted, PQ16 high side mosfet of the 1.8v rail badly damaged with a hole on the middle of it, SI4800 maybe, can´t read it, replaced with FDS8884 as indicated in the schematic, now the 1.8v rail present but PQ16 heats up a lot instantly, can someone have an idea on what to check please ?
    Also disconnected PJP4 no change, PQ16 heats a lot !
    Schematic:
  • Lex-
    • May 2011
    • 18
    Re: HP 520 LA-3491P High Side MOSFET Heat Problem
    Someone who can help me please ?
    • caspian
      • Oct 2015
      • 1591
      • Laptop
      check the 19v rail for being shorted to ground. If it was shorted, search the entire mainboard to see why 19v is shorted. do not plug the laptop in until the short is gone.
      • khaahk
        • Dec 2013
        • 812
        • Estonia
        What is resistance from PL7 to gnd after PJP4 open?
        PU11 might be dead after PQ16 shorted.
        • Lex-
          • May 2011
          • 18
          caspian:
          19v rail not shorted to ground.
          khaahk:
          Fluke 26III, red probe connected to ground, black probe connected to PL7:
          ohms scale: 0.892 k ohms
          continuity (beep) scale: 149.3 ohms
          Note: if I invert test probes (black to Gnd, red to PL7) then no read -OL.-
          Thank you.
          • Lex-
            • May 2011
            • 18
            Any advice ?
            Thank you.
            • dougg3
              Intel DX58SO high side VRM MOSFET keeps failing
              by dougg3
              Hi there,
              I have an Intel DX58SO motherboard that failed last year. One of the high side VRM MOSFETs failed shorted, and it killed my i7 980 CPU. This motherboard has a 6-phase VRM. The parts used on this motherboard's VRM are:
              • 6 x High side MOSFET: NTMFS4841NH
              • 6 x Low side MOSFET: NTMFS4834N
              • 6 x Driver: ADP3121JCPZ
              It was easy to figure out where the short was, because the bad MOSFET's gate was shorted to the drain/source too. Once I removed it, all the shorts were gone on the motherboard, and I confirmed on the removed MOSFET itself that the gate/drain/source...
              10-17-2021, 07:39 PM
            • c_corr
              Asus P4C800-E VRM issues
              by c_corr
              This board had the initial fault in VRM with high side Mosfet from PWM1 (phase 1) getting very hot. It also had the VRM caps quicly heating up in 10-15 seconds after power on.
              This board uses mext ICs and Mosfets in VRM:
              - ADP3180 PWM controller - in 3 phase mode
              - ADP3418 as Modfet drivers
              - High side Mosfets STD38NH02L (from ST)
              - Low side Mosfets STD90NH02L
              Some of the symptoms were very similar with the "Dead Asus P5P800-VM" in this forum.
              I had the sawtooth voltage on Vcore too this was probably the cause of the Vcore caps...
              02-08-2025, 11:59 PM
            • Nooy
              VGA MOSfet permanently shorted and loss of MOSfet pad
              by Nooy
              Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
              I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
              02-14-2024, 02:26 AM
            • zwerw3
              High side mosfet of the power supply of the RTX2060 graphic chip burned out
              by zwerw3
              Hello. They brought a personal computer for repair in which the video card was GeForce RTX ™ 2060 WINDFORCE OC 6G (rev. 1.0). Graphics core power mosfet burned out.
              Is there a chance to restore the site where the mosfet was? I started to grind the mosfet substrate with a dremel, which stuck to the board, but for now I stopped and decided to ask you for advice. I also noticed dark spots on the PCB near the video memory chips. Does this mean that the video memory is out of order? I cleaned the place where there was a burnout, a short circuit of 12 V was removed. On the coils on the power...
              12-12-2022, 12:15 AM
              Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
              The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
              Securing a good thermal interface between...
              10-07-2024, 04:35 AM
