Core i7 short to ground, possible cause?
  • hgg
    • Oct 2014
    • 24
    • Greece
    Hi guys,
    I am trying to troubleshoot a used laptop motherboard I bought which refuses
    to power on. Before the problem, I've installed a mSATA SSD and installed
    Windows without any problems. At the end I powered off the laptop and I
    wanted to install an antivirus as well. After the shutdown it never powered on
    again.
    I removed the motherboard and what I found was a short to ground on the
    5V rail. After a lot of searching I could not find the faulty component and
    I injected 3V @ 3A in the 5V rail in order to see what component will get hot.
    This was the result :
    It looks like that there is a short somewhere on the i7 CPU!
    You can actually see the temperature rising pretty fast the moment you
    connect the power supply :
    The hotspot is on the lower left side of the CPU die. The back side is cool.
    Is this motherboard toast ?
    How common is it to have a short to ground on the CPU?
    Is there anything else that I can check ?
    Thank you for your help!
    George.
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: Core i7 short to ground, possible cause?
    probably multiple points are shorted.
    now check all coils to find another shorted coil.
    If the CPU is soldered and is shorted, probably this board does not worth repairing.
    • hgg
      • Oct 2014
      • 24
      • Greece
      On the CPU you mean?
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        no, you have to search for short all over the mainboard where there is a coil.
        • khaahk
          • Dec 2013
          • 812
          • Estonia
          What mainboard? How did you locate the 5V rail? Do you have schematic? How many ohms is short to ground? Usually it is not necessary to inject over 1V to find what is heating.
          CPU-s die too, thats correct.
          • hgg
            • Oct 2014
            • 24
            • Greece
            @khaahk Its a Lenovo laptop and I have the schematics.
            Yes 3V was not necessary. It was a 5V rail though.
            @caspian I measured all the inductors for shorts to ground:
            L26 (5V) : 0.8 Ohms
            L27 (3V) : M Ohms
            L24 (Charger Out) : 20 KOhms
            L25 (5V) : 0.8 Ohms
            L34 (VCCSA) : 22 Ohms
            L31 (VCC1R05AMT) : 78 Ohms
            L29 (VCCGFXCORE) : 6.8 Ohms
            L30 (VCC1R05_VTT) : 0.8 Ohms
            L32 (VCC1R5A_VX) : MOhms
            5V rail is shorted for sure.
            Now L30 looks like a short as well and VCC1R05 might be the CPU voltage.
            Its connected on the output of the VT357FCX-ADJ (DC-DC Converter)
            I cannot find any detailed data on the VT357FCX-ADJ.
            It looks like its the DC-DC converter that takes 5V in and converts it to 1V.
            Is it possible then that this is the component that shorts the 5V and the 1V rails?
            The thing is that the motherboard heats up only on the CPU and nowhere
            else and the CPU does not use 5V afaik.
            What do you think?
            Thanks.
            • caspian
              • Oct 2015
              • 1591
              • Laptop
              upload the schematics file to have better understanding.
              is the CPU soldered to the board?
              yes.
              Now look for short on the components connected to VT357FC and L30 and L26 and L25.
              capacitors and Mosfets have got the highest probability of being shorted.
              • hgg
                • Oct 2014
                • 24
                • Greece
                I have already found the components that have a short because
                thats where I started from. Two MOSFETs on the 5V rail present
                a short, but that does not mean they are actually shorted. Anything
                on the 5V rail could be the cause. For example all the capacitors
                on the same rail present a short. That is why I used high current to
                find out what was getting hot.
                The thing is that if its the VT357FCX that shorts the rails, then why
                it does not get any hot ???
                You can find the schematics online : https://goo.gl/XZ1n1v
                • hgg
                  • Oct 2014
                  • 24
                  • Greece
                  Just checked and there is a direct short (0.35 Ohms) between VDD (input) & VXD (output)
                  of the VT357FCX chip.
                  • caspian
                    • Oct 2015
                    • 1591
                    • Laptop
                    now you have to replace suspected components by new ones until no short exists on the mainboard. To save money, only replace suspected capacitors and Mosfets at the first step. and let controller ICs stay.
                    The thing is that if its the VT357FCX that shorts the rails, then why it does not get any hot ???
                    If it is not getting hot, then it is not a serious suspect of being shorted. So leave it alone for start. After replacing suspected capacitors and Mosfets, you may conclude that VT357FCX is either faulty or healthy.
                    If the CPU is soldered to the board, you may need to replace the CPU as well.
                    • hgg
                      • Oct 2014
                      • 24
                      • Greece
                      The CPU is soldered to the board, so replacing it its out of the question because
                      I do not have anything close to a BGA rig.
                      When you apply current to the shorted rail isn't logical to assume that only the
                      shorted components will get hot? The only thing that gets hot is one side of
                      the CPU die.
                      • caspian
                        • Oct 2015
                        • 1591
                        • Laptop
                        only one of shorted components gets hot and other shorted components stay either cold or a bit warm.
                        • hgg
                          • Oct 2014
                          • 24
                          • Greece
                          So, maybe its more convenient to start removing inductors and see which part of
                          the circuit remains shorted in order to close on the faulty component.
                          What do you think?
                          • caspian
                            • Oct 2015
                            • 1591
                            • Laptop
                            yes, this is a good idea.
                            • hgg
                              • Oct 2014
                              • 24
                              • Greece
                              Great, I think this is what I will try.
                              I will let you know.
                              Thank you very much for your help!
                              • hgg
                                • Oct 2014
                                • 24
                                • Greece
                                The 1.5V rail inductor L30 has been removed and the 5V rail cleared
                                of any shorts. MOSFETs and capacitors are all ok now!
                                If you have a look at the diagram some posts above, pin 1 of R819 (VDD) and
                                pin 1 of inductor L30 (VXD) of the DC-DC VT357FCX chip still have a short.
                                Does this mean that the IC is definitely fried ?
                                The other thing is that on the VT357FCX pin VCC_SENSE_VTT is also
                                shorted to ground and a series of capacitors along the CPU VCC1R05
                                rail are all shorted to ground (C113, C115 etc)
                                How can we find out if the DC-DC vs the CPU are causing the short now.
                                The DC-DC is a tiny BGA chip and it would be quite difficult to resolder
                                once removed.
                                • hgg
                                  • Oct 2014
                                  • 24
                                  • Greece
                                  Ok, with L30 removed, I applied 0.7V/1.5A to pin 2 of L30 and I got the same
                                  thermal signature. Lower right side of the CPU in the photo getting hot again.
                                  Although the DC-DC chip shorts its input with its output please have a look at
                                  the following component schematic:
                                  All the blue pins are interconnected with the remaining shorted rail.
                                  The marked capacitors on the lower left are all shorted to ground as well.
                                  As you can see, this line goes to the DC-DC chip VT357 as well. (lower right)
                                  Is it possible that the short is been created by this chip and that the CPU
                                  is actually fine?
                                  Thank you.
                                  • caspian
                                    • Oct 2015
                                    • 1591
                                    • Laptop
                                    all the components which you mentioned cannot be shorted. Usually, one or two components are shorted. you have to test them one by one to discover the shorted ones. or you can apply an external voltage that has the risk of burning the CPU or PCH.
                                    • hgg
                                      • Oct 2014
                                      • 24
                                      • Greece
                                      I have tested the capacitors on the lower left and they are all sorted to ground.
                                      • caspian
                                        • Oct 2015
                                        • 1591
                                        • Laptop
                                        they cannot be all shorted.
                                        if one of them is shorted, the multimeter shows the two lines shorted for all the parallel capacitors.
                                        • playit
                                          450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
                                          by playit
                                          hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
                                          09-02-2023, 02:43 AM
                                        • JimMc0
                                          Gigabyte GA-H61M-USB3-B3 dead short 3.3v rail to ground.
                                          by JimMc0
                                          Hi there,
                                          I discovered this forum through a youtuber who teaches electronic repair. I've been trying to troubleshoot my dad's old PC which is a Gigabyte GA-H61M-USB3-B3 and will not power on. I discovered a dead short on the 3.3v rail at the ATX connector so I used a bench power supply to feed 3.3v into the ATX connector and sunk about 400mA into the board (I hope that's not too much!). I used a FLIR camera to identify the problem area:
                                          The chip seems to be the following, an ITE IT8892E 1108-CXS which seems to be a PCI bridge?
                                          03-27-2024, 08:36 AM
                                        • Victor Moreira Silva
                                          Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                          by Victor Moreira Silva
                                          I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                          Well, my decice specs are the following:
                                          Model: Acer Nitro 5 AN517-54-55T5
                                          CPU: Intel Core i5-11400H
                                          GPU: NVIDIA GeForce GTX 1650
                                          Motherboard: GH51G LA-L181P Rev:1c
                                          The symptom:
                                          When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                          05-26-2025, 10:49 AM
                                        • grimacelord
                                          Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
                                          by grimacelord
                                          Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
                                          After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
                                          I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
                                          10-24-2024, 12:31 PM
                                        • nagkiller
                                          Asus Geforce Cerberus GTX1050TI-O4G-DIS short circuit in the FBVDDQ rail
                                          by nagkiller
                                          Hello everyone!
                                          This grafic card came for repair, but when I connected it to the motherboard, the board would not start (short circuit in the 12V rail).
                                          After removing some PLs to isolate the short in the 12V rail, I got to PML1/PML2, according to the BoardView reference.
                                          Even injecting a voltage of 1V0 and a current of 3A in the FBVDDQ rail, for example, the voltage drops to 0V20 and none of the components heat up.
                                          The attached boardview file is very similar to this grafic card, which I am basing the repair on.
                                          I would like some...
                                          05-10-2025, 09:19 AM
