Core i7 short to ground, possible cause?
  • hgg
    • Oct 2014
    • 24
    • Greece
    Re: Core i7 short to ground, possible cause?
    That's what I mean.
    This line is shorted to ground and either the CPU or the VT357 is creating the short.
    • caspian
      • Oct 2015
      • 1591
      • Laptop
      check which third component is parallel on that line. That third component may be shorted.
      • hgg
        • Oct 2014
        • 24
        • Greece
        Which 3rd component? There are a lot on this line!
        There is the DC-DC converter VT357 and it has its input shorted with its output.
        Is it possible that this is what is creating the problem?
        • caspian
          • Oct 2015
          • 1591
          • Laptop
          yes it is possible, but not so probable.
          first check whether a parallel capacitor or mosfet is shorting the input and the output of VT357.
          • hgg
            • Oct 2014
            • 24
            • Greece
            The output of VT357 has been completely disconnected because I removed L30.
            • caspian
              • Oct 2015
              • 1591
              • Laptop
              #26
              now remove VT357 to check whether the short gets gone or not.
              • hgg
                • Oct 2014
                • 24
                • Greece
                #27
                Hmm, yes, that's what I want to avoid because its a 25 pin BGA 2x2mm in size..
                I guess I have no other choice though.
                • caspian
                  • Oct 2015
                  • 1591
                  • Laptop
                  #28
                  you need a powerful soldering microscope and a lot of care.
                  • hgg
                    • Oct 2014
                    • 24
                    • Greece
                    #29
                    I have this one but its nothing near what you should have for the job...
                    https://www.amazon.com/Opti-Tekscope.../dp/B00PEZ3GMK
                    • caspian
                      • Oct 2015
                      • 1591
                      • Laptop
                      #30
                      it provides a small working space under the camera.
                      so the camera may be damaged by the heat you apply to the board.
                      If I get rich some day, I will buy an AmScope.
                      • hgg
                        • Oct 2014
                        • 24
                        • Greece
                        #31
                        Yes indeed, that's what I have in mind as well.
                        • Biswash
                          • Feb 2017
                          • 10
                          • NEPAL
                          #32
                          i need bios of lenovo v110
                          • playit
                            450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
                            by playit
                            hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
                            09-02-2023, 02:43 AM
                          • JimMc0
                            Gigabyte GA-H61M-USB3-B3 dead short 3.3v rail to ground.
                            by JimMc0
                            Hi there,
                            I discovered this forum through a youtuber who teaches electronic repair. I've been trying to troubleshoot my dad's old PC which is a Gigabyte GA-H61M-USB3-B3 and will not power on. I discovered a dead short on the 3.3v rail at the ATX connector so I used a bench power supply to feed 3.3v into the ATX connector and sunk about 400mA into the board (I hope that's not too much!). I used a FLIR camera to identify the problem area:
                            The chip seems to be the following, an ITE IT8892E 1108-CXS which seems to be a PCI bridge?
                            03-27-2024, 08:36 AM
                          • Victor Moreira Silva
                            Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                            by Victor Moreira Silva
                            I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                            Well, my decice specs are the following:
                            Model: Acer Nitro 5 AN517-54-55T5
                            CPU: Intel Core i5-11400H
                            GPU: NVIDIA GeForce GTX 1650
                            Motherboard: GH51G LA-L181P Rev:1c
                            The symptom:
                            When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                            05-26-2025, 10:49 AM
                          • grimacelord
                            Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
                            by grimacelord
                            Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
                            After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
                            I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
                            10-24-2024, 12:31 PM
                          • nagkiller
                            Asus Geforce Cerberus GTX1050TI-O4G-DIS short circuit in the FBVDDQ rail
                            by nagkiller
                            Hello everyone!
                            This grafic card came for repair, but when I connected it to the motherboard, the board would not start (short circuit in the 12V rail).
                            After removing some PLs to isolate the short in the 12V rail, I got to PML1/PML2, according to the BoardView reference.
                            Even injecting a voltage of 1V0 and a current of 3A in the FBVDDQ rail, for example, the voltage drops to 0V20 and none of the components heat up.
                            The attached boardview file is very similar to this grafic card, which I am basing the repair on.
                            I would like some...
                            05-10-2025, 09:19 AM
