Recently I got a faulty laptop charger. Now that I want to make it work. How should I start with and what tools should I have at my disposal?
					Find fault in charger
			by motormayhemLaptop Question
 I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
 A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
 NVDC charger configuration...-
							Channel: Common Parts Library - Datasheets
 11-05-2024, 03:28 PM
			by flat-eartherI have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
 So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
 but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
 So the battery is backfeeding the charger and being drained.
 How can I prevent...
			by JohndillHi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
 There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
 I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
 Here are the tested scenarios:
 1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
 2. With the laptop off, plug in charger (LED says on) & the front charging...
			by claws77this is a cross post.
 the laptop charger does not work. no output voltage.
 removed 18V and GND cable from secondary, left ID cable-- suspecting short in output cord and then measurements were made.
 input cord is fine -- checked. 220 V AC
 primary transformer voltage (V_DE) is fine - checked 310.1 VDC
 secondary transformer voltage is 0V (V_AB) -dont know why
 C1 and C2 are electrolytic caps marked at 470uF but reads 987 uF -- seems connected in parallel. V_c1 =0V and V_c2 = 0V....06-15-2024, 06:46 AM
- Loading...
