Lenovo G580 7981P accidently shorted Q83
  • Technolix
    • Mar 2014
    • 15
    I've bought 3 Lenovo G580s from a friend, all with different defects.
    On this particular board, the 7981P with discret graphics, he shorted Q83 near the LVDS-Connector by dropping the LVDS-Plug on to Q83 while under power.
    I then replaced Q83 from another board but still no luck.
    What else do I should check? The board starts but no display. Using Vga, my monitor says out of range but is capable of 1920x1080.
    I've attached the schematic plus top and bottom of the board. I've circled the replaced component.
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: Lenovo G580 7981P accidently shorted Q83
    Does the OS actually boot? (ie. is it really a "no display" situation and not a "not POSTing"?)
    Shorting Q83 to ground shouldn't be that bad, something else have probably happened. It sounds like it is only for the camera, and a quick short to ground on +3VS shouldn't have destroyed anything else.
    Check voltage on all pins of Q83 to make sure everything is ok here.
    • Technolix
      • Mar 2014
      • 15
      I have no hdd with a OS on it but I've cross checked with a working QIWG6 LA-7988P board, where I have 3.3V on Pin 3 and 2 of Q83.
      On the LA-7981P I have 3.3V on Pin 3 but 0V on Pin 2.
      I've bought the working LA-7988P Notebook to upgrade it, so the LCD, cable etc. are all functioning.
      • Technolix
        • Mar 2014
        • 15
        Seems I'm missing the 3V line.
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • modtool
          HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
          by modtool
          Hi to all,
          the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
          I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
          I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
          04-01-2025, 08:22 AM
        • Dylan Jones
          MacBook A2681 (Board 820-02862) - UP700 Likely Shorted
          by Dylan Jones
          I'm a beginner at laptop repair. I bought a MacBook Air A2681 that doesn’t turn on, just for practice. PPBUS_AON and the other always-on voltages are present and look fine. I did some diode mode measurements and got unusual readings (compared to reference values I found online) on LC320 (44mV) and L82D0 (40mV). LC320 corresponds to the PP5V_S2 power rail, and L82D0 to PP1V25_S2.
          I injected 1V (current limited to 100mA, the board consumed around 86mA) into PP1V25_S2 to see if anything would heat up, but everything seemed normal. I did the same with 5V (current limited...
          06-28-2025, 05:07 PM
        • Habble7
          Lenovo ThinkVision P40w-20 no power – ILPI-422 VA board repair help
          by Habble7
          I'm trying to repair the power supply board from a Lenovo ThinkVision P40w-20 monitor. The board is labeled with the following markings:
          - Main PCB code: ILPI-422 VA (dated 2021/11/24)
          The monitor is completely dead, no power LED or backlight. Upon inspection, I found a few components that appear damaged, particularly some resistors that are burned and unreadable.
          Attached is a high-resolution photo of the power supply board.
          Does anyone have a schematic, boardview, or similar power supply that can help identify the...
          05-15-2025, 02:38 AM
