Lenovo Yoga unidentified component
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    after a short circuit , the npn mosfet has burned, after a replace now the voltage reaches the motherboard but I have identified another component that has sign of burns.
    I have the schematic but seem that the U40 is not the same.
    Someone can identify this component.
    thanks
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Lenovo Yoga unidentified component
    U40 looks like the same as in the schematics to me.
    • jiroy
      • Jun 2016
      • 2416
      • Lebanon
      Are you sure ? , it's on Page 30/37 ..
      TPS2553DRV_SON6_2X2
      • jiroy
        • Jun 2016
        • 2416
        • Lebanon
        I think your confusion comes from this mosfet having 7 pins .. Notice that the seventh pin is a ground pad ..
        • jasko_jacker
          • Oct 2014
          • 1140
          • italy
          Ok (the gnd pad is under the component), i do not understand the function of this component.
          • jiroy
            • Jun 2016
            • 2416
            • Lebanon
            It's a part of the USB system , so if shorted , yes , it would prevent booting .
            • piernov
              • Jan 2016
              • 4439
              • France
              Basically it's a switch that enables/disables USB power depending on the signal present on the EN pin. Additionnally, it provides protection against over-current situation on the USB port.
              Remove U40 and inject 5V on its output and check if the current is higher than it should be.
              If it's fine (less than 1.5A) then you can put a jumper from input to output for testing purpose only. You'll have to replace U40 in all cases.
              • jiroy
                • Jun 2016
                • 2416
                • Lebanon
                I really wonder what "something USB" could have drawn more than 1.7 Amps , lol ..
                • jasko_jacker
                  • Oct 2014
                  • 1140
                  • italy
                  I never fixed a motherboard of this type and If I understand well how it works:
                  for the moment I can not consider u40 because it does not receive + 5VDX_WALKPORT (right ?), coming from ISL95905
                  this is an IC Integrated Power Management (all in one, provides all the necessary voltages to major components, cpu, ram etc) and I think I should check if it works.
                  the datasheet is not available
                  • jiroy
                    • Jun 2016
                    • 2416
                    • Lebanon
                    It would be difficult but not impossible , to determine the IC status . Try first to identify the health of the IC other's voltages . If things are constant and true , then the IC is fine and working .
                    In such case , you could follow the tps255XX surrounding components ..
                    • jasko_jacker
                      • Oct 2014
                      • 1140
                      • italy
                      No voltages out from PU3, it is powered by 8.4V .
                      Charge chip is ok, ITE is not powered but I have difficult to detect the +3v source without boardview.
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Why dont you remove U40 from mobo and see what happens?? Its not going to harm as its only usb power,usb port will not work. Sometimes a burnt IC may prevent other voltage rails. Just think about it.
                        • jiroy
                          • Jun 2016
                          • 2416
                          • Lebanon
                          It's logical to assume jasko_jacker; has removed U40 by now. No reason to leave a burnt component anyway .
                          If ISL95905HIZ-T is acting strange , better replace it , it's available from manufacturer Intersil Corporation .
                          • jeroengroen
                            • May 2015
                            • Nederland
                            I have a board with no burned components, but u40 was shorted. I've replaced that, but same as poster: no power reached. I've measured the +5VUSB on the ISL95905 and that seems to be shorted. I'm waiting on a new one now. Did you ever solve it, or do you need more info on where I measured?
                            • Armandio92
                              • Mar 2023
                              thanks
                              Hi, we're you able to fix it? Replaced both components and still the same. I'm lost even with the schematics. CPU and BQ chip run at 40c under Thermal cam.
                              • chenwei
                                • Feb 2023
                                • 40
                                • china
                                This is the USB power supply chip. Can be removed directly. Then the sub 1, 6 feet
                                  Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook 700 Specification for Upgrade or Repair
                                  This specification for the Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 7i (16? Intel) 2 in 1 Laptop boardview and Yoga 7i (16? Intel) 2 in 1 Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                  09-07-2024, 05:00 AM
                                  Lenovo Yoga X1 Yoga Gen 6 Hybrid (2-in-1) Specification for Upgrade or Repair
                                  This specification for the Lenovo Yoga X1 Yoga Gen 6 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Yoga Gen 6 boardview and X1 Yoga Gen 6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                  Lenovo Yoga Yoga 6 13ALC7 Notebook Specification for Upgrade or Repair
                                  This specification for the Lenovo Yoga Yoga 6 13ALC7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 6 13ALC7 boardview and Yoga 6 13ALC7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                  Lenovo Yoga Yoga 6 13ALC7 Notebook 700 Specification for Upgrade or Repair
