Problem in motherboard/Slot of memory
  • kulatrax
    • Sep 2017
    • Portugal
    Hi dear fellows,
    First of all, please note that I will talk about a laptop problem, not about desktop/builds. I have a laptop with a HM76 Chipset and I've upgraded from an i5 3210M to an i7 3630QM, so perfectly compatible. I also bought an additional stick of 8GB RAM with dual voltage of 1.35V and 1.5V, from Crucial (according to the information on the Crucial's website, I think they are both running at 1.5V).
    But, when I finish the assembling and press the power button, the PC boot but it was on a black screen, even the logo of "ASUS" don't appear, so it failed to POST. After some tests, I discover the problem was in RAM slot 1. If I put any stick of RAM in slot 1 the laptop has the mentioned problem. If I only use the slot 2, with 1 stick of RAM, everything works perfectly and the boot is super normal.
    In some of the times I could boot the PC with the 2 sticks of RAM in the 2 slots doing what is presented in this video (https://www.youtube.com/watch?v=js6DNbZDJ1o) what may indicate dirty in the slot/stick but I have already cleaned everything with a can of Air compressed. But in other times I cannot boot normally the PC
    I've test individually each stick of RAM and they are good (I stress test it in memtest86 and memtest86+). But, if I put a stick of RAM in slot 1, in the times when I can boot the PC, doing a stress test with memtest86 and Prime95 I got some errors and BSoD. With a stick of ram in slot 2 I have 0 errors, even with stress test of 15 hours both in memtest86 and Prime95.
    So, this may indicate that I have a problem in slot 1 right? What do you think that have caused this, because it just appeared after upgrading the CPU ?
    And, more important: Do you think if I leave the slot 1 empty and use only the Slot 2 I could have future problems? Because buying a new motherboard or repair this one will be a little bit expensive, and if using only slot 2 and ignoring the damage in slot 1 would not result in aditional problems/damages, it would be a good thing for me.
    I appreaciate every opinion you could give me,
    I wish you all a great week!
    Best regards.
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Problem in motherboard/Slot of memory
    Check RAM/CPU socket and CPU pins and make sure everything looks good. Use some contact cleaner to clean the CPU socket and the RAM socket. If you can stress-test it without issue with RAM only inside the other slot, the CPU is probably fine but somewhere between the RAM and the CPU there is probably a bad contact. Just put the maximum amount of RAM inside the working slot and you should be fine.
    • kulatrax
      • Sep 2017
      • Portugal
      Hi Piernov, thank you very much for your help. I think I have already saw one of your videos on youtube, about fixing a motherboard. I'm very happy to have your help.
      You said: "If you can stress-test it without issue with RAM only inside the other slot, the CPU is probably fine" when you said "with RAM only inside the other slot" you mean RAM only in Slot 2 right? If so, yes, I stress test with 8GB RAM on slot 2 for 15h in memtest86 and 15h in Prime95 and everything was OK. The max heat was 90ºC what I think is good (the Tj max for this CPU is 105ºC) and no BSoD and not errors on Memtest86.
      So, you're saying that if everything is OK when the Slot 1 is empty the CPU is probably fine? But can't be a problem in the CPU that is just affecting the Slot 1 and not Slot 2?
      What you say here "Just put the maximum amount of RAM inside the working slot and you should be fine" is that you recommend me to ignore the damage in Slot 1 and use 8GB in slot 2? That's what I'm alredy doing, but someone have told me that somewhere in the future the Slot 2 will have the same problem, and I'm worry about that. And, with 8GB of RAM, I'm always with 65% to 80% of RAM usage on task manager.. but I think I can optimize it and close some things..
      I will appreciate your opinion again, please.
      Thank you
      • pkslowk
        Debug Card Error Code and Solution
        by pkslowk
        Sr. Motherboard Debug Error Code Solution
        1 Intel 845 E9 Bios Related Problem
        2 Intel 845 D4 CPU Socket Related problem
        3 Intel 845 37 Bios Related Problem
        4 Intel 845 7C Bios Related Problem
        5 Intel 945GCPE 34 Bios Related Problem
        6 Gigabyte 845 2 Ram Related Problem
        7 IBM Server A6 A7 Ram Mismatch Problem
        8 Asus 845 29 CPU Related Problem
        9 Lenovo I946 97 C-Mos Jumper related
        10 Gigabyte 845 A0 CPU Related Problem
        11 Asrock G31M-VS D7 Bios Related Problem
        12 Compaq 845 BD-70G B0 CPU Socket Related problem...
        01-28-2021, 12:51 PM
      • theone111
        by theone111
        3. Problem: TV shuts down
        07-22-2024, 10:36 AM
      • totoagung2
        by totoagung2
        Totoagung2: Situs Slot Gacor Paling Gampang Jackpot di Indonesia 2024
        Hadirnya situs slot gacor gampang jackpot Totoagung2 yang menyediakan banyak sekali permainan slot terpopuler terkini yang hadir setiap tahun nya. Tentunya di Indonesia sendiri yang menjadi salah satu negara yang favorit bagi provider game slot. Banyak sekali pengembang permainan melihat negara tanah air Indonesia untuk menjadikan dan mencoba berbagai kesempatan bisnis judi online yakni games judi slot Totoagung2 terbaik dan terpercaya no 1. Hal itu juga dibuktikan dengan sangat banyaknya provider mesin slot...
        01-01-2024, 02:43 PM
      • Zeonalbasta
        Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
        by Zeonalbasta
        i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
        The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
        09-13-2024, 01:17 PM
      • perzyk23
        Lenovo T580 - LCD Panel problem - error 0288
        by perzyk23
        Good morning,
        I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
        10-25-2024, 12:42 AM
