Lenovo G50-30 dead, no lights at all
  • xfce
    • Aug 2017
    • 18
    • Bulgaria
    hello , i`m working on lenovo g50-30 motherboard : ACLU9/ACLU0 NM-A311 Rev: 1.0 . I was following the suggests on this post https://www.badcaps.net/forum/showth...ghlight=g50-30
    . So far what i`ve done is to check PQ301 ,PQ302 and PU301 is where i end up.Except the pins i`ve market with RED on the picture, rest of the pins i get 0v. You can see my results from the attached pictures,schematic also attached, so my question is what should i do now ? thank you in advance
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Lenovo G50-30 dead, no lights at all
    Replace charger IC PU301 and measure voltage on all its pins again.
    • xfce
      • Aug 2017
      • 18
      • Bulgaria
      hi and thanks for your help. Dont need to replace anything, i just found if there is a short on the cmos battery means the CPU is burned and on this motherboard CPU is everything. I`m just sharing that to save the work for the next one who will deal with this model.
      • Dimitrios
        • Nov 2013
        • 127
        • Greece
        Also for me PQ302 mofset was broken after some measurements I took and stopped the current to flow through. Replaced it and now I got a proper opening laptop!
        • coasterghost
          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
          by coasterghost
          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
          System Hardware:
          Processor: AMD Ryzen 7 PRO 5850U
          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
          09-08-2025, 10:46 PM
        • bialag
          Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
          by bialag
          I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
          Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
          03-25-2025, 05:56 PM
        • Nagyesz
          Lenovo ideapad 330ICH - Dead, no volts on coils
          by Nagyesz
          Hi everyone, I replaced this motherboard because it was important to get it working, but it's been with me for a very long time. Now I finally have time to figure out what the problem is,
          I've never encountered something like this before;
          No charging light, full dead
          Lenovo Ideapad 330-17ICH
          • PL3102: 5 ohms
          • PL3001: 3.2 ohms
          • PL3101: 2 ohms
          • PL5801: 3.5 ohms
          • PL5501: 270 ohms
          • PL701: 35 ohms
          • PL501: 146 ohms
          • PL503: 390 ohms
          • PL402: OL (0.27V) +5VALW_P
          • PL301: OL
          • PL401: OL (0.03V) +3VALW_P
          + Dc-in mosfet @PQ311 pin 5 20v, pin 1-4 0V , @PQ312 no volts...
          10-11-2024, 10:12 AM
        • Zmay2509
          Lenovo T14 nm-c931 1th gen intel 10th DEAD
          by Zmay2509
          Hi, I have dead t14 gen1 with nm-c931 motherboard.
          Laptop doesn't turn on and does not show any sings of life.(battery is completely flat, do I need it for power on??)
          When I connect usb c power adapter it draws 0.02A at 20v, I get voltage 20.5V up to 2nd mosfet and nothing out (PQ0006 before current resistor and buck-boost) when I touch gate pin of PQ0006 with tweezers it opens and I get 20.5v on current resistor;
          But even with that "trick" I cant get laptop to turn on, that's probably because BQ25700ARSNR is not happy and not making VSYS15 rail.
          03-25-2025, 02:44 PM
        • reformatt
          Lenovo NM-A921 (Yoga 900-13ISK2) dead
          by reformatt
          This machine has been in a few times with an intermittent fault of not charging. Motherboard is NM-A921 (https://www.badcaps.net/filedata/fetch?id=2051581)
          So back again now, not working at all. Previously the adaptor had been replaced along with the DC charge port. This is one of these trapezoid shaped orange USB ports that Lenovo were using prior to going USB-C. It has 4 pins, but the DC connector jack on the PCB has 5 pins.
          Fault presentation was the adaptor is only producing 5.2V, not 20V and this isn't reaching the input of the NVDC charger (PQ5/PQ6). There are 5...
          02-05-2025, 05:24 PM
