Dell inspiron 3421 Not Charging short on battery
  • razu
    • Jan 2015
    • 218
    • Bangladesh
    Hy all friends ,
    The laptop is ok ,,,,,its start on adapter, when i insert battery, the laptop is totally short.......
    but I change battery, its same problem
    Thanks in advance
  • Acnologia
    • 421
    • Poland
    Re: Dell inspiron 3421 Not Charging short on battery
    Originally posted by razu
    Hy all friends ,
    Thanks in advance
    Check on the battery ic chip that is responsible of changing the "circuit" if i write it correct, from AC to Battery.
    • razu
      • Jan 2015
      • 218
      • Bangladesh
      r you sure 100 % sure
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        likely to be a mosfet failure around ac -in or charging section
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • danielsak
          Dell Inspiron 3542 (Cedar_Intel-MB 13269-1) - RTC battery self-discharging and Realtek LAN issue
          by danielsak
          Hello, I have issue with Dell Inspiron 3542.
          Motherboard marking:
          Code:
          PWB FX3MC REV: A00
          The laptop works just fine (on battery and power supply) and doesn't cause any problems, except those described below:
          1. The first problem is that the RTC/CMOS battery self-discharges after about 2-3 weeks after installing a new battery. I have been installing different batteries (GP, Duracell, Energizer) and the problem still exist.
          1. The second problem is the LAN network card (Realtek RTL8106E), which is not detected at all in Windows. The BIOS is
          10-11-2024, 04:36 PM
        • ipatch
          dell inspiron 5567 laptop battery lipo WDX0R
          by ipatch
          recently i was gifted a dell inspiron 5567 for wiping the data on the hard drive. (yay me). however i already have a computer that i use, so i have no need for this computer. this computer wasn't without its problems though.
          1. i had to purchase an adapter to retrofit my older style dell laptop battery cable. (not too expensive) ~= 10 bucks for a 2 pack via amz.
          2. after that i had to find a spare cr2032 (easily found in my parts bin) and assemble a makeshift cmos battery thanks to some copper foil tape and some heat shrink tubing.
          got the computer...
          04-02-2023, 04:45 PM
        • lawrenceptrini
          Battery not charging - Dell Inspiron 3593 FD155 LA-JO81P (REV 1.0) (A00)
          by lawrenceptrini
          Hi Guys,
          I am seeking some assistance with a Dell Inspiron 3593 FD155 LA-J081P (REV 1.0) (A00) laptop
          The laptop is working fine with the adapter plugged in and also with a charged battery.
          Problem is that the laptop is not charging the battery. The battery is recognized in the bios but the
          ac adapter is listed as 'Not Installed'. So for instance, when a charged battery from another source
          loses its charge, it stays on 0%.
          Measurements taken
          Charging IC (ISL95522HRZ) 32 pins
          Voltage to ground with ac adapter only plugged in:
          1)...
          08-26-2024, 06:45 PM
        • HTR-Informatique
          Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
          by HTR-Informatique
          YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
          I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
          On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
          I also changed the screen because the PC fell and the screen was broken.
          I changed the battery with a new and original battery.
          I also had corrosion/oxidation on the...
          02-09-2025, 06:51 AM
