E1-772g Not powering on and not charging
  • questore
    • Dec 2015
    • 563
    • csongrád
    Re: E1-772g Not powering on and not charging
    Q8302 is shorted to ground just I suspected, thats why theres is no 1.35v so obviously no power for +VCORE. tomorrow I remove it to see whats next.
    As I see schematics there is 2 mosfet connected the same way so maybe Q8303 can take its place while I order a new one and i can go further if there is more problem.
    • questore
      • Dec 2015
      • 563
      • csongrád
      removed Q3202 something not right around DDR voltage chip.
      - S3 and S5 seems fine 3.3v
      - V5IN is fine 5.04
      - DRVL 0v
      - DRVH 0.1V
      - SW 0.1V
      - all resistors seem to be fine around it
      • questore
        • Dec 2015
        • 563
        • csongrád
        Help!
        • questore
          • Dec 2015
          • 563
          • csongrád
          - V5IN is fine 5.04
          - DRVL 0v
          - DRVH 0.1V
          - SW 0.1V
          Sorry removed not Q3202 but Q8302.
          • flat-earther
            ASUS X54H laptop thinks it's always charging even with charger unplugged
            by flat-earther
            The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
            Windows also shows ''Plugged in'' when charger is not connected.
            This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
            Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
            If I let battery run out and say it has 3% Windows will...
            06-24-2025, 09:32 AM
          • serious_electron
            Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
            by serious_electron
            Hello Everyone!
            I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
            06-28-2025, 02:57 PM
          • flat-earther
            how to prevent a connected charger from draining battery when not charging?
            by flat-earther
            I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
            So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
            but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
            So the battery is backfeeding the charger and being drained.
            How can I prevent...
            08-07-2025, 01:04 PM
          • dimis1975
            Macbook A1466 2014 not charging with macsafe 2 charger
            by dimis1975
            I have a macboook air a1466 that stopped charging the battery.
            BAT PINS: with or without ADAPTER IN
            1- GND
            2- GND
            3- GND
            4-0V sense pin
            5-3.42V
            6-3.42V
            7- 8.4V
            8- 8.4V
            9- 8.4V
            AC Adapter plugged in: after a lot of of hours some times start charging
            No BAT Connected- Green to Orange
            AC Adapter plugged in: BAT Connected- no light
            The strange thing, when I tried a mac charger usb-c with usb-c to macsafe 2 adapter works normally and charging.
            Any ideas what’s wrong please?...
            08-05-2025, 03:43 AM
          • coasterghost
            Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
            by coasterghost
            For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
            Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
            Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
            System Hardware:
            Processor: AMD Ryzen 7 PRO 5850U
            Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
            09-08-2025, 10:46 PM
