LA7401P Short to ground
    Hi there.
    I have a LG laptop that was completely off. I open and check on the board, there was 2 burnt mosfets (PQ401 and PQ402). I removed them from the board and tried to plug the laptop, the laptop switches on and goes off after a few seconds. Now I replaced both mosfets, the laptop don't switch on and PQ401 is overheating(very hot). Where can I test and how can I resolve this issue? Any help is much appreciated. I have attached the schematics and a pic of the affected area.
    Re: LA7401P Short to ground
    measure resistance to GND on all pins of PQ402.
      Must I put back PQ402 on the board? because I removed both pq401 and pq402
        now that you removed them, just measure resistance on the empty pads of the two transistors on the board.
          ok.
          pq401
          pin 1 to 3 = 391 ohm
          pin 4 = displays 1700 ohm then meter goes to 1
          pin6 to 8 = displays 1700 ohm then meter goes to 1
          pq402
          pin 1 to 3 = 008ohm
          pin 4 = 1415 ohm
          pin6 to 8 =225 ohm
          ps: I put the negative prove on the ground and the positive probe on pins to test. is that okay?
            it is ok.
            now measure voltage on pin4 of pu401 before pressing the power button.
            then measure voltage on pin1 of pu401 after pressing the power button.
              pin4 of pu401 = 4.38V before pressing the button and pressing the button it stays the same, 4.38V.
                what about pin1 of pu401?
                  Hi there
                  Pq401 Voltage:
                  pin 1 to 3 = 0.02v
                  pin 4 = 4.39 v
                  pin 5 to 8= 18.99v
                  Pq402 Voltage:
                  pin 1 to 3 = 0.0
                  pin 4 = 0v
                  pin 5 to 8 = 0.02
                  ps: both Mosfets are off the board. I am only testing the pads.
                  thank you for your assistance
                    pin1 of pu401 is important.
                      what do you suggest?
                        PU401 pin 1 = 0.1v
                          you must measure this pin less than 1 second after pressing the power button.
                            Cool, PU401, pin 1
                            before pressing the button= 0.01
                            After pressing the button = 0.03
                            what does this mean?
                              it means the laptop has also got another problem on some power rail.
                                5V alw and 3V alw are present before pressing the button, what other power rail can I check?
                                  Could you please quickly explain to me how this 1.5 circuit works (Pq401, Pq402 and the PU401 that controls the mosfet?
                                    I think the problem is somewhere else on the board.
                                    now you have to check voltage on the following pins of KB930 after turning on:
                                    26, 65, 76, 95, 100-to-117, 121, 125.
                                      Hi Caspian. I tried to remove the inductor, PL401 these are the measurement I got:
                                      PQ401
                                      pin 1 to 3 = 1.70v (before pressing the button) 3.56v (after pressing the button)
                                      pin 4 = 4.26v (Before and after pressing the buttonn)
                                      pin 5 to 8= 18.7v
                                      PQ402
                                      pin 1 to 3 = 0.01v (before pressing the button) 0.03v (after pressing the button)
                                      pin 4 = 0.03v (Before and after pressing the buttonn)
                                      pin 5 to 8 = 1.70v (before pressing the button) 3.56v (after pressing the button)
                                        So I assume that there is a problem in the 1.5V power rail on the board side. what is your thought about this? Thank you for your responses
