FPT tool and error 201 upgrade ME
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Hi all
    On an asus N550J the bios haven't me region, I have prepared the
    correct file but when I try to flash the bios with fpt , it return a 201 error probably due to
    Me region missing. There is another tool to make this or the only way is open the case and use a programmer ?
  • Djosla
    • Dec 2012
    • 246
    • Montenegro
    Re: FPT tool and error 201 upgrade ME
    it has to have me region but it must be in other eeprom...post all dumps and i will recreate it for you...
    • Sus256
      HISENSE 65E7KQ PRO - no boot
      by Sus256
      Hi all!
      HISENSE 65E7KQ PRO
      RSAG7.820.13512 - chassis
      MT9618BAATAB - cpu
      RSAG7.820.12059 - power
      HD650Y3U77 - panel
      KLM8G1GETF - emmc
      Replaced emmc.
      Terminal log
      UART
      AC_ON
      E-B
      FDE enabled
      06-01-2025, 02:11 AM
    • kuba2102
      Macbook Air M2 A2681 NAND upgrade error 35
      by kuba2102
      Hello people. I have undertaken an upgrade from 256GB to 512GB. I have another A2681 board that I sourced NANDs, resistors and capacitors from. Yet when I try to restore the firmware in FDU mode I get the error 0x23 (35) (error formatting the NAND). Could it be the faulty NAND or I have missed something? Thank you...
      07-03-2025, 12:20 PM
    • rex98
      HP DMI Tool
      by rex98
      HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
      DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
      The DMI Tool given here are for personal use only.
      DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
      You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
      from it, and that you please credit the author...
      07-02-2025, 05:51 AM
    • bohaboha
      error code 0x80072f8f 20000 When widows upgrade to 10
      by bohaboha
      when upgrading windows 7 to windows 10 i get this error code (title).then to correct the error i have to enable tls 1.1 and tls 1.2 in registry editor. but there I do not find TLS 1.1 and TLS 1.2 instead there is SSL2.0
      in REGISTER EDITOR on windows 7 ad can one do to correct the problem?
      Error Code 0x80072f8f 20000
      08-30-2023, 07:06 PM
    • CapThatBrass
      CSE/Layout Project Error Message - FIT Tool
      by CapThatBrass
      Has anyone come across the attached error message whilst using CSME System Tools v16.0 r3.
      I've just loaded up an XML generated from the same application, and the error appears with no real clue as to how to fix it:
      Exception: Error occurred whilst trying to create container CseRegion. Reason Mismatch between CSE version and layout project version
      Layout Accepts: 16.0.x.y
      CseVersion: 16.1.25.2128
      Source: CsePlugin: CseRegion
      Source: CsePlugin
      Thanks in advance (hopefully someone knows....)...
      06-13-2023, 12:17 PM
