please can any one help me with Acer MS2394 Schematic?a customer brought it to me with a water spillage on mobo and after drying the mobo i tried to see if board will work by putting it on,its worked when i pressed the power bottom but after insetting the HDD to see if mobo will work ok it went off with powering again,please can anyone help me?tnx in advance
					Acer MS2394with dead board
 Assuming...7 Photos
			by Destroyer-Br[HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
 I'm working on an Acer Nitro 5 unit with the following specs:- Motherboard: LA-J871P Rev: 1B
- Model: Acer AN515-55-59MT
- S/N: NHQ7JAL00403906A973400
- SNID: 03902728734
 Initial Issue
 The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
 After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
			by k370Hi everyone,
 I have a NM-A321 board that is dead, with no power at all.
 When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
 With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:- +3VALW
- +5VAUX
- 1.2VSUS_PWRGD
- 3VALW_PGD
- 1.05VAUX_PWRGD
 Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
 The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
			by Roman555I'd like to offer an Acer IPIMB-AR Rev: 1.02A fullflash BIOS (cleaned ME region). The model is for Acer Predator G5920.
 It is a model that is based on Intel Z77 PCH and doesn't have on-board graphics and video connectors.
 I suppose it doesn't have any restriction about discrete graphics cards (I mean they don't have to be in a whitelist).
 Please don't mistake this mainboard with a similar model with on-board graphics and based on Intel B75 PCH.
 Jumper FLASH_OVERRIDE
 default position: 1-2 - BIOS area protected
 position 2-3 allows to dump BIOS or write...-
 06-26-2025, 05:15 AM
			by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
- Loading...
