Dell N5010 LVDS voltage issue
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Model-Dell N5010 with Intel Graphics Only(No Ati)
    m//b-DG15-09909-1
    Problem: Display characters are showing red instead of white.
    Laptop boots fine with display-no issues other then colour issue.
    Here are the voltage measured at Lvds connector(measured with Display cable plugged in and with display on screen)
    Pin 01/02/03-19v
    pin 04-0v
    pin 05/06-3.3v
    pin 07-3.3v
    pin 08-3.3v
    pin 09-3.3v
    pin 10-3.3v
    pin 11 to 23-0v
    pin 24/25-1.20v
    pin 26-0v
    pin 27/28-1.2v
    pin 29-0v
    pin 30/31-1.2v
    pin 32-0v
    pin 33/34-1.2v
    pin 35-3.3v
    pin 36-3.3v
    pin 37-0v
    pin 38-0v
    pin 39-0v
    pin 40-3.3v
    I think there is some voltage missing in lvds connector. What's your suggestion?? Please advice
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Dell N5010 LVDS voltage issue
    Forgot to mention that i have changed screen as well as lvds cable.Still same-red display in characters instead of white.
    schematics also attached
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      No Idea Friends or anyone can post lvds pin voltage from a working m/b??
      • mielta
        • Apr 2015
        • 368
        Hi
        is it from ext Monitor CRT or HDMI also ?
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          External monitor display is ok. Problem only in internal display
          • mielta
            • Apr 2015
            • 368
            hi
            When you have checked The LCD Cable and the screen then i think its PCH Intel
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Originally posted by mielta
              hi
              Yes,Finally i changed Pch, Now ok. Thanks for your suggestions
              • SuperJames
                Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                by SuperJames
                This one's a weird one, and still unsolved despite it having gone back to Dell once.
                Specs
                i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                Backstory
                I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                10-23-2023, 04:09 PM
                Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                by sam_sam_sam
                I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                Now...
                06-09-2024, 10:57 AM
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • computerbacon79
                Dell Inspiron 3480 All in One corrupt Bios issue: reaches Dell logo and stops
                by computerbacon79
                The Dell Inspiron 3480 I own (the all in one, not the laptop) is not wanting to turn on at all. It goes right to a dell logo, but it stays there forever with no other information on the screen. Holding the automatic Bios repair key combo (ctrl+esc) that should let it read a recovery file off a USB drive gets stuck on a black screen and does nothing. No amount of resetting anything so far has worked, and Dell's own support downloads have not really helped. Ive tried another BIN file I found online using my CH341A, and this got me slightly more, that time it displayed a loading bar that never moved...
                05-06-2025, 06:43 PM
              • Ven
                Dell Latitude 3510 Overheating & Fan Control Issue – Need Help
                by Ven
                Dell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
                Issue Description:
                1. CPU Overheating to 100°C
                  • When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.​
                  • When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
                  • However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
                  • I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
                  • Thermal
                02-12-2025, 03:57 PM
