hp 15-r263tu auto off problam
  • Sanjeewait
    • Aug 2016
    • 63
    • Sri Lanka
    hp 15-r243tu laptop auto off how to fix it
    this error not a over Heating. m/b error plz help me
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    Re: hp 15-r263tu auto off problam
    send old bios
    fix intel me region.
    • Sus256
      HISENSE 65E7KQ PRO - no boot
      by Sus256
      Hi all!
      HISENSE 65E7KQ PRO
      RSAG7.820.13512 - chassis
      MT9618BAATAB - cpu
      RSAG7.820.12059 - power
      HD650Y3U77 - panel
      KLM8G1GETF - emmc
      Replaced emmc.
      Terminal log
      UART
      AC_ON
      E-B
      FDE enabled
      06-01-2025, 02:11 AM
    • edugimeno
      Thermozyklus ZE5 Heating Controller. Bus error
      by edugimeno
      Hi! I was given this board. Its supposed to be a heating controller. It can be programmed over othernet from a computer, and can manage different outputs via a "BUS" connector (there's suppossedly an external module where this BUS wires enter with some relay outputs that power on/off heating valves for different rooms
      The owner stated something like "I reversed the polarity and although the manual states that's its made to withstand reverse polarity, and would wanr the used onscreen, it ended up broken and would say "shortcut in output" all the time, or something...
      03-16-2024, 04:33 PM
    • Superbee_dad
      Sharp 80” long short flash backlight error - Help
      by Superbee_dad
      Hello Sharp TV experts
      Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
      > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
      > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
      01-24-2025, 11:51 PM
    • Maalobs
      Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
      by Maalobs
      I have a 2014 vintage Philips 60PFL8708S/12 that suddenly died in the middle of the kids watching a show.
      The relevant service manual for the chassis is available here.
      The TV no longer powers on, and leaving it powered on for a few minutes results in the layer-1 error with 2 blinks.
      When I short the SDM to ground I get the layer-2 error code 53.
      The inside of the TV has no damaged components and no swollen capacitors.
      In SDM-mode when all the power rails are left on despite entering the protection mode, I tracked down and measured...
      04-02-2019, 01:15 PM
    • shouri
      Dell latitude e5490 auto restart
      by shouri
      Hi guys, can someone help me?
      I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
      Board model is dm70 la-f401p rev:1.0 2017-09-20.
      At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
      After a few days test, is seems ok.
      Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
      12-10-2024, 09:27 PM
