Macbook A1466 mb 820-3437 keyboard not work
  • Pragmatiko
    • Jul 2013
    • 468
    • IT
    Hello all,
    i have that laptop with keyboard problem.
    The keyboard is not working, i have already replaced the whole palmrest but still i have problem.
    Checked voltage on J4800 keyboard connector and they are presents.
    Any help?
    Thank you to all
  • techman1025
    • Jun 2014
    • 497
    Re: Macbook A1466 mb 820-3437 keyboard not work
    Hi
    Your touchpad is could be bad or corrosion around connectors
    Be aware that there are 2 different versions of keyboards in these models and you may need MRI tools to flash the new trackpad to match the keyboard. Otherwise the function keys may not work.
    Techman1025
    • Pragmatiko
      • Jul 2013
      • 468
      • IT
      Originally posted by techman1025
      Hi
      Techman1025
      Thank you very much for your reply.
      Where i can find more info about thar MRI tools?
      • highpulse
        i hate HP
        • May 2013
        • 1488
        • portugal
        techman always showing lots of knowledge
        how you doing mate ? hope that good !!
        • chanpreyveng
          • 7
          • Cambodia
          hello pls check R4844 =0 if it more than 0 replace it
          • Pragmatiko
            • Jul 2013
            • 468
            • IT
            thank you, yer R4844 is 0 ohm
            • techman1025
              • Jun 2014
              • 497
              Hi
              Maybe cable in dead doing a ohm test on both ends to confirm good or bad again inspect connector reflow if needed . Also this might help: http://advancedreworks.com/forum/sho...lt-639-28.html
              Techman1025
              • Pragmatiko
                • Jul 2013
                • 468
                • IT
                Hi
                Techman1025
                cable is new, i have eplaced all palmerst with cable. Also i have exchanged circuit with where is located nand flash. The problem seem on motherboard, but i checked it with microscope and seem all ok .
                • Pragmatiko
                  • Jul 2013
                  • 468
                  • IT
                  Solved:
                  client have replaced palmrest with wrong version
                  • techman1025
                    • Jun 2014
                    • 497
                    Hi
                    This is why you never listen to what other have done Like i said in the early post(2 different versions of keyboards in these models)
                    Good job
                    Techman1025
                    • Pragmatiko
                      • Jul 2013
                      • 468
                      • IT
                      Hi
                      Good job
                      Techman1025
                      No no, your alert opened my eyes. Thank you very much.
                      • MICHAEL_2013
                        • Feb 2016
                        • 54
                        • Colombia
                        Please, where i can find more info about thar MRI tools? Thanks.
                        • hollox123
                          ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                          by hollox123
                          Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                          1. Laptop keyboard doesn't work
                          2. The backlight on the laptop keyboard doesn't work
                          3. The x2 side LEDs (red) on the laptop don't work
                          The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                          I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                          But I am strongly aiming that it is somehow a BIOS-related problem,...
                          05-11-2025, 08:05 AM
                        • playit
                          ps/2 port keyboard dead ? p5ql pro / ethernet cable light
                          by playit
                          my system is p5ql pro asus mobo , logitech keyboard ps2 keyboard (more than 10 years) .
                          my place use to get some power drip for a second ,at that time , pc shuts and restarts itself , it dint cause any problem till now , once or twice i noticed , i am not sure if it was exactly at power drip time or normal time - both keyboard and ethernet lan stopped working , the keyboard would lose power i mean led lights-num lock caps lock would not stay on , no light at etherbet cable too..then i would restart the pc - then its all good .
                          few years back ps2 mouse stopped working, but ps2...
                          12-23-2024, 06:05 AM
                        • slimmy182
                          A2289 MacBook keyboard and trackpad does not work anymore
                          by slimmy182
                          hello, my A2289 MacBook keyboard and trackpad does not work anymore. keyboard backlight is working, Touch Bar is working but I can’t use it. if I connect external keyboard and external mouse all work perfectly, but internal keyboard and trackpad does not work. The Apple Hardware Test completes with the error PPF003 indicating that the fan is not working properly. (PPF004). does it worth try to change keyboard and trackpad? or Maybe I need logic board repair? I take apart trackpad and no signs of corrosion
                          04-17-2021, 03:55 AM
                          HP ProBook 430 G5 + Essential 15.6-inch Case, Keyboard & Mouse Notebook 400 Specification for Upgrade or Repair
                          This specification for the HP ProBook 430 G5 + Essential 15.6-inch Case, Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G5 + Essential 15.6-inch Case, Keyboard & Mouse boardview and 430 G5 + Essential 15.6-inch Case, Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...
                          09-06-2024, 06:21 AM
                          HP ProBook 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook 400 Specification for Upgrade or Repair
                          This specification for the HP ProBook 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse boardview and 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you...
