I urgently need help with dell laptop,when I put in the charger I hear a continues sound on the board and when you press the power switch the power led comes on and goes off few seconds with the sound still coming from the board,I don't know what to do about it and can anybody help me with this,the mobo number is LA-6471P Rev:1.0
Dell laptop with power problem
Tags: None
Re: Dell laptop with power problem
model number of your dellI urgently need help with dell laptop,when I put in the charger I hear a continues sound on the board and when you press the power switch the power led comes on and goes off few seconds with the sound still coming from the board,I don't know what to do about it and can anybody help me with this,the mobo number is LA-6471P Rev:1.0 -
model number of your dellI urgently need help with dell laptop,when I put in the charger I hear a continues sound on the board and when you press the power switch the power led comes on and goes off few seconds with the sound still coming from the board,I don't know what to do about it and can anybody help me with this,the mobo number is LA-6471P Rev:1.0Comment
please this is the model is Dell inspiron P08T and the mobo number is LA-6471P Rev:1.0,tnxComment
with the sound on the board,could it be a bios problem please?Comment
if not then what may be the problem?because when i switch on the power U34 becomes warm and power led goes off again,can anyone at all help me withoutComment
pls can I get the board view and schematic for the mobo LA-6471P Rev 1.0Comment
by masoksianHi everyone,
I am dealing with the problem of turning on and off my Dell e7470 notebook.
The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
The system does not turn on, there is no post.
I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
The problem continues in the same way.
I tried to turn on the Fn key, nothing came to the screen.... -
by CicciotestHi everyone,
I have a problem with this dell mini desktop, no LED lights up and there is no response from the front power button. It literally feels defunct, with no feedback whatsoever.
IPCML-CT motherboard rev.A00
CPU: Intel Celeron G5900T
I tested the power supply (19.5v correctly) but to be careful I also used an alternative power supply to test, nothing. No LEDs, no power on.
I tested the power button pins and they correctly measure 3.3V, so when I press the button or put a bridge with a wire, the pulse seems to be there correctly.
...06-06-2024, 08:48 AM -
by Mark01Hi guys,
This is my first post! 🚀
I have no idea what I’m doing, but I’m learning by trial and error.
I’m currently working on a Dell Optiplex AIO 7490—one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...07-04-2025, 12:54 PM -
by zlr8rhey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
Ill try and give as much info as I can.
Dell Inspiron 17 (7786) Laptop
Service Tag: 5J0NHT2
Bios: 1.9.0
When I received this , it would only flicker on the KB backlight for a second, then off and on.
Then it started getting weirder!
Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has... -
by theone111I have an LG Plasma TV 60PM6700 for the past ~12 years.
In the last ~3-4 months I have been having some issues.- Problem: It started with random picture disappearing (sound still worked).
Solution: Had to turn off TV wait a few seconds before turning it on again. - Problem: Then it got worse and the TV started to shut down and when turning on the no picture just sound.
Solution: Had to turn off TV wait about 10-20 seconds and turn it on again to solve. - Problem: TV shuts down
1 Photo - Problem: It started with random picture disappearing (sound still worked).
- Loading...
