Hp 15 with power problem
  • emmanuelbill1988
    • Mar 2017
    • 100
    • ghana
    please i urgently need help with this Hp notebook 15,when you put the charger the power jack light comes on but laptop does not on when power button is pressed,i check for voltage from the power jack to the board and i get 19v,3.3v and 5v respectively, even at the power switch i get 3.3v which the laptop suppose to on but does not,really need help on where to check or how to solve it please,tnx very much
  • cacla
    • Apr 2015
    • 444
    Re: Hp 15 with power problem
    Try to flash bios
    • emmanuelbill1988
      • Mar 2017
      • 100
      • ghana
      kk,but can someone help me with bios dump for HP 15,
      board number LA-A994P REV:2.0
      • cacla
        • Apr 2015
        • 444
        try this one
        https://www.badcaps.net/forum/showth...light=LA-A994P
        • theone111
          by theone111
          3. Problem: TV shuts down
          07-22-2024, 10:36 AM
        • Duranitron
          Asus x512dk rev 2.1 power on problem
          by Duranitron
          When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
          Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
          11-26-2024, 10:22 PM
        • EazyBone
          LG OLED55C9PUA power problem
          by EazyBone
          Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
          Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
          I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
          The power supply to t con is different story.
          This...
          06-23-2023, 07:43 AM
        • Dr.d
          Help please..Lenovo ideapad 5 14itl05 power and charging problem
          by Dr.d
          I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
          Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
          04-05-2024, 11:48 AM
          03-31-2024, 02:12 PM
