Lenovo ultrabook u510 li ion battery in sleep.mode how to wake up
  • sureshbobby
    • Mar 2015
    • 137
    • India
    Lenovo u510 battery dead after full discharged
    Its not waking up with charging showing that 4 min to full charge
    Is there anyway to bring back to life
    It is 11.1 li ion battery pack
    No signs of voltge at battery
    Is it possible to boost withdc power supply if possible please guide me
    Thank you friends and techies
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Lenovo ultrabook u510 li ion battery in sleep.mode how to wake up
    No, the battery's microcontroller probably entered permanent failure mode. You can't do anything about it, just buy another battery. You could still try to leave it charging for a few hours, but it will probably not charge.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      or u can disassembly it and charge the cells
      • piernov
        • Jan 2016
        • 4439
        • France
        @ktmmotocross if it is in permanent failure mode, the fuse is blown and the controller is disabled. Charging the cells manually won't help and it can be dangerous if you don't know how to charge lithium cells.
        You can however extract the cells and save them for another battery where the cells are worn out, if the cells themselves are still good.
        • sureshbobby
          • Mar 2015
          • 137
          • India
          Hi Friends,
          Thank you so much for your suggestions. By luck or what the battery is back to life again and acting as normal. i have run the gauge test in lenovo energy manager. after that its been starting working again. Hurray it saved me $40.
          Thank you all
          • sureshbobby
            • Mar 2015
            • 137
            • India
            Most probably li Ion battery will go to sleep mode because of fully discharge. i thought that it happens to my battery.
            • ferah831208
              by ferah831208
              03-18-2025, 01:18 AM
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • code share
              Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
              by code share
              I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
              Here's what I've tried so far:
              • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
              • Booted successfully on AC power only with the battery disconnected
              • Visual inspection of the battery — no swelling, burn marks, or connector damage
              • Battery
              04-21-2025, 12:50 PM
            • mrkmpn
              Lenovo Yoga C930-13IKB EYG70 NM-B741 Battery not detected.
              by mrkmpn
              Hello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
              This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,...
              03-13-2024, 01:54 PM
            • pabloroggeri
              Lenovo V310-15ISK - It doesn't work after changing the battery
              by pabloroggeri
              Good guys. I changed the battery to a Lenovo V310-15ISK.
              The laptop worked perfectly, I changed the L15C4A02 battery because it didn't last very long.
              When I connected the new battery, the charging LED stopped lighting up and the one next to the charging pin also did not react when I pressed the power button. Minutes before changing the battery it worked perfectly and stopped working after putting the new one in. Even if you put the oroginal battery in or connect it without the battery, no LED lights up when you press the power button nor does it give an image, nor does the...
              08-23-2024, 12:01 PM
