Weird Problem with Zenbook UX31la
  • maxoscar
    • Apr 2015
    • 10
    • syria
    I have the below strange problem with Zenbook UX31LA :
    -If the battery is connected, The laptop boot up using the battery mode regardless if the AC charger is being plugged in or off.
    -The laptop could power up using the AC charger if the battery is disconnected,
    The only way to let them both work together is to follow the below sequence :
    1- Disconnecting the battery.
    2-Booting up using the AC charger.
    3-While the laptop is working, connecting the battery again (I know this is unsafe but this is the only way)
    I have updated the BIOS , but the problem hasn't been solved.
    Please Advice
    Thanks in advance
  • cacla
    • Apr 2015
    • 444
    Re: Weird Problem with Zenbook UX31la
    You have problem with first or second mosfet form DC pin. Today i have the same problem.
    • maxoscar
      • Apr 2015
      • 10
      • syria
      Hello again and thanks for your answer
      would you please help me how could I find the suitable mosfet (Number ) ?
      • cacla
        • Apr 2015
        • 444
        First measure which one is faulty
        • maxoscar
          • Apr 2015
          • 10
          • syria
          Sorry for the dumb question as I am a newbie in this field, which is the better way to test the MOSFET:
          - check if there is a shortage between the MOSFET's legs. Also between MOSFET's leg and the ground.
          - while the laptop power on, check the input and output on the MOSFETS' leg 19v
          are the above steps are the correct procedure, Thanks
          • maxoscar
            • Apr 2015
            • 10
            • syria
            Any idea?
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3627
              • slovakia
              every way is good. more measuring data, more u know for repair
              • maxoscar
                • Apr 2015
                • 10
                • syria
                Hello again
                I have checked the mosfet today with multi-meter and there is a shortage in the mosfet between the drain and the source . How could I purchase a substitute item.
                Thanks in advance
                • maxoscar
                  • Apr 2015
                  • 10
                  • syria
                  Any idea, please ?
                  • rtstorm
                    • Feb 2012
                    • 971
                    • Croatia
                    Do you have a schematics? If yes then read value for that fet, or use a magifierband read the text from mosfet
                    ...the quieter you become the more you are able to hear...
                      ASUS ZenBook Zenbook 14 Flip OLED UN5401QA-KN144W Notebook Specification for Upgrade or Repair
                      This specification for the ASUS ZenBook Zenbook 14 Flip OLED UN5401QA-KN144W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Zenbook 14 Flip OLED UN5401QA-KN144W boardview and Zenbook 14 Flip OLED UN5401QA-KN144W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                      09-07-2024, 06:31 AM
                    • chaos-theory
                      Nitro rx580 very weird problem, VCORE and EN
                      by chaos-theory
                      Hello!
                      I have this very weird problem, I got this rx580 nitro saphire and the fans don't even spin but the saphire logo is lit.
                      All voltage rails are present except for VCORE at the coils, then I started checking NCP81022 and it has voltage but vdd pwrgd is missing, enable EN is missing it shows 2.5ohm, everything seems fine, i tried checking the back of the card, to see where the enable pin goes, i dont have a schematic so i started touching randomly until i measured a resistor on the back and the fans started spinning, now I was amazed like what is wrong here? So I thought it's a...
                      08-17-2024, 04:56 PM
                    • motormayhem
                      Lenovo T460 Only Charges on One Charger
                      by motormayhem
                      Laptop Question
                      I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                      A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                      05-12-2023, 01:46 PM
                    • flat-earther
                      ASUS X54H laptop thinks it's always charging even with charger unplugged
                      by flat-earther
                      The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                      Windows also shows ''Plugged in'' when charger is not connected.
                      This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                      Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                      If I let battery run out and say it has 3% Windows will...
                      06-24-2025, 09:32 AM
                    • c.daniel
                      Lenovo V310-15IKB weird bios problem...
                      by c.daniel
                      Lenovo V310-15IKB Type 80T3 laptop, i7 7th cpu with dedicated Ati video
                      sn LR09493E
                      MB DAOLV6MB6F0 REV. F
                      The laptop was working fine, the only problem was that when I turned it on, the screen was hard to turn on, it would wait for about 30-40 seconds before an image appeared on the screen.
                      Initially, I updated from windows to Intel Management Engine 11.8 Firmware, restarted, everything was fine.
                      Then I updated the bios, also from windows, to the last vs, vs 46. It restarted, those lines with bios update progress appeared, restarted and that's it, since then...
                      08-22-2025, 05:39 AM
