Asus x55a problem
  • heavymachines
    • Mar 2011
    • 1028
    Re: Asus x55a problem
    please list actual readings like this .001 or 1.111 whatever you're getting. if high resistance or almost dead short...
    • Morsus
      • Nov 2016
      • 96
      • Serbia
      Originally posted by Djosla
      Nijesi me dobro ukapirao...na programator da ga flesujes...ne diraj ostalo jer je mozda u redu...Nizak otpor moras da imas u kolu aktivnih cipova...to je normalno...
      To be fair to the rest of the forum I suppose we should continue on English
      I'm not sure how to flash bios without a display.
      Readings do vary about +-0.10V every time I measure on the bottom transistor. All other values are fixed.
      • heavymachines
        • Mar 2011
        • 1028
        You would need need one of these..eBay item number:182492676824
        to be able to flash it not being able to boot laptop. Or buy a preprogrammed bios and soldier it in or make your own interface to ic and rom software to flash it...
        Readings are fixed, in diode or ohms? Actual readings please .001 on source of fet? 111? , without designators and pin numbers with actual readings makes things very confusing and can give wrong data.
        • Morsus
          • Nov 2016
          • 96
          • Serbia
          Okay, this is where I am now. Since I don't own a device for bios programming or programmable bios chip I discarded that idea. (Couldn't find the item by that number either, but I did google a lot).
          I took all 3 transistors off for testing and the each show 750 on diode mode between drain and source. Sooo the transistors should be good, right?
          I didn't try to take caps off since they have a plastic bottom and I didn't want to make a bigger mess than it already is. (you can see that the pink/red color did come off from caps top)
          So, can I test anything else now while I have these off?
          • Morsus
            • Nov 2016
            • 96
            • Serbia
            bump
            • Morsus
              • Nov 2016
              • 96
              • Serbia
              #26
              Update:
              Without processor and these 3 transistors the pins on bottom connector are shortened. First two are shortened and second two between themselves.
              Also I made another image of all contacts shortened to the ground.
              • heavymachines
                • Mar 2011
                • 1028
                If you're certain it is shorted within itself replace. that cap with missing paint should be replaced got way too hot. Not enough flux used or none at all and add fresh soldier and flux to get it too come off with iron at less time therefor with less heating time. Chipquick works good for removal of smd devices. Use regular flux for putting back in. You check for shorts on mosfet between gate and drain. https://www.youtube.com/watch?v=fOGAhaVH06I
                Again http://mayohardware.blogspot.com/201...g-mosfets.html.
                • piernov
                  • Jan 2016
                  • 4435
                  • France
                  #28
                  No I think it's perfectly fine, nothing shorted here.
                  (the only thing would be the 3 MLCC caps between the two coils and the CPU socket on the left, but it's probably fine)
                  You get good VCore so this section is perfectly fine in my opinion.
                  Does the OS boot anyway? (ie. you can hear the hard drive heads moving)
                  • Morsus
                    • Nov 2016
                    • 96
                    • Serbia
                    #29
                    I will check the cap that has no paint on. Also will replace the 3 MLCC caps.
                    Hmm.. not sure anymore. I remember hearing it work but I can't remember if HDD started or not :/ I will assemble it all back together tomorrow to start it again and make sure if its starting or not.
                    • Morsus
                      • Nov 2016
                      • 96
                      • Serbia
                      #30
                      Okay I have assembled all back together started it and the HDD did start. So everythign is basically working but the screen internal or external. I also took the first cap in row below CPU witch showed up to be a little bad (about 450uF instead of 560uF) but I don't think that it is the culprit. I am looking for a replacement cap atm.
                      • piernov
                        • Jan 2016
                        • 4435
                        • France
                        #31
                        Ok so the OS is booting (hard drive heads moving for quite some time)? Caps lock/Num lock works?
                        Check voltage between PL8004 and ground near the CPU socket.
                        It's the inductor on the right of the CPU socket in this picture (the big gray square):
                        https://www.badcaps.net/forum/attach...0&d=1490374156
                        Also do you have backlight or is the screen doing anything?
                        • piernov
                          • Jan 2016
                          • 4435
                          • France
                          #32
                          It may be the issue, but I'm not sure which cap you're talking about?
                          • emmanuelbill1988
                            • Mar 2017
                            • 100
                            • ghana
                            #33
                            please just cook the board,it will work
                            • cacla
                              • Apr 2015
                              • 442
                              #34
                              Pls tray to reprogram bios with this bin its working bin file
                              • Morsus
                                • Nov 2016
                                • 96
                                • Serbia
                                #35
                                No backlight no anything 100% dead, same on external screen.
                                I cant measure anything until I replace the missing cap.
                                I am not cooking the board.
                                Also I can't reprogram the bios since I don't have the right equipment (I am in process of getting it tho).
                                Okay, back to the cap. I have nowhere to buy same one at my place all I got are these:
                                Original cap - 560uF / 2.5V (2J2)
                                Spare ones I got?
                                651uF/6.3V (FP5K/FP) or 820uF/2.5V (E110/ULR).
                                Could I use any of these?
                                • cacla
                                  • Apr 2015
                                  • 442
                                  #36
                                  I know this board you have problem with bios if you wish this board to work you must flash bios on programmer.
                                  • cacla
                                    • Apr 2015
                                    • 442
                                    #37
                                    Here repair guide
                                    • piernov
                                      • Jan 2016
                                      • 4435
                                      • France
                                      #38
                                      You can flash the BIOS using a Raspberry Pi for example. Always remember to make a backup. It would be preferable that you try this before trying to change components since you may damage the board by doing so.
                                      • FriedFred
                                        ASUS ROG STRIX G713IC-HX041W, Mainboard G513-MP-GBM, battery shorted out
                                        by FriedFred
                                        6050A3249305-MB-A01
                                        2021-11-05
                                        Hello, everyone!
                                        I have some trouble with the G513-MP-GBM board, it's from an ASUS ROG STRIX G713IC-HX041W.
                                        The total current consumption was about 200mA. The 0.8 Volt rail at the CPU was correct working.
                                        But the power button has not been pressed...
                                        I found some spurious solder between the pads 6 (VRA_SVT) and 7 (APU_PWR_EN) of the PWM-controller, "U66000".
                                        Which can explain why this power rail has been starting without...
                                        01-19-2025, 09:00 AM
                                      • AtelierRepa
                                        ASUS X712JA problem
                                        by AtelierRepa
                                        I have a problem with the bios, let me explain.
                                        With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
                                        I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
                                        My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
                                        The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....
                                        06-15-2024, 04:33 AM
                                      • Dobrowol
                                        Asus GA402RK keyboard and kb backlight problem
                                        by Dobrowol
                                        Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
                                        04-28-2025, 04:30 PM
                                        ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook CX1 Specification for Upgrade or Repair
                                        This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
                                        09-07-2024, 02:50 AM
                                        ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
                                        This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
