w355stq
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    w355stq
    hi guys , here we are again after sometime of disapearance ,
    got here clevo w355st one of many we got here to fix , this machine was with short on 3VA line , analising hm87 was in short in the 3.3volts line . so replaced it , and short is gone , the machine turned on , took some second to give image and entered the bios , shut it down , added the hdd to try it on windows , machine turn on , no image..
    started cheking things again , Vcore on cpu is at astonishing 1.78 volts .. damm thats not good , cheked things around NCP ,all seem ok , cpu replaced same issue , ncp replaced same issue , sense resistors all ok , temp resistors ok ...
    my question is , problem wich PCH could originate such high voltage on the cpu core ? (pch is another i had on another clevo board)
    but it did worked on biggining .. here it is schematic
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3577
    • slovakia
    Re: w355stq
    v core is just another step-down circuit. if u have bad voltage u have something bad in that circiut.
    • piernov
      • Jan 2016
      • 4435
      • France
      Re: w355stq
      I'm not sure about this but I think on Haswell CPUs the VCore buck controller is actually controlled by the CPU itself to give the proper VCore. So if the CPU doesn't work/doesn't turn on, it cannot regulate its VCore correctly.
      • dycc
        Vision
        • Nov 2011
        • 624
        • Côte d'Ivoire
        Re: w355stq
        i know that lynx point pch have processor of 4th generation and the voltage is correct
        • dycc
          Vision
          • Nov 2011
          • 624
          • Côte d'Ivoire
          Re: w355stq
          also high impedance compare to other generation . 1.6~1.7 v to operate
          • dycc
            Vision
            • Nov 2011
            • 624
            • Côte d'Ivoire
            Re: w355stq
            begining from the first to the 6th VCore is controlled by the CPU itself ( vid ,svid).
            • randomrat
              Alienware X15 R2 LA-L611 No power
              by randomrat
              ​Not having the best of luck with my own gadgets atm - I own two identical X15 R2 laptops, both have died suddenly with no prior issues. I have time to focus on one of them and in this post. I might need some hand-holding with this so I kindly ask for some understanding
              Make: Alienware
              Model: X15 R2
              Motherboard: LA-L611
              CPU: i9-12900H
              GPU: RTX 3080Ti
              History: I was using the machine as normal when it suddenly switched off and never came back on. I've owned the machine for over a year and use a Dell Thunderbolt Dock to charge my laptop with....
              03-29-2025, 12:18 PM
            • kotel studios
              Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
              by kotel studios
              Finally got time to fix this board up.
              At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
              Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
              04-22-2025, 05:08 AM
            • piernov
              Core 2 "gaming" build with SLI
              by piernov
              My turn to post a build I guess, wasted way too much time on this one…
              First proper SLI board I get so wanted to play around a little bit since I got a couple 8800 GTS.
              Everything done with random parts I had lying around.
              Specs :
              • CPU: Core 2 Quad Q9450
              • RAM: 2x2GB KHX6400D2K2
              • GPUs: 2x Nvidia GeForce 8800 GTS G80 320MB
              • MB: P5N-E SLI
              • PSU: Antec Basiq Power 550 Plus
              • HDD: Hitachi Ultrastar A7K2000 1TB
              • ODDs: DVD ROM, DVD RW
              • Case: not sure
              Cooling:
              • 92mm rear fan
              • 120mm front fan
              • Additional heatsink on southbridge
              05-20-2023, 11:38 AM
            • taxxin
              Zotac gtx-750ti 2gb vcore short
              by taxxin
              Dear Members,
              I would like some of you to share your experience with Vcore shorts to determine whether or not this card is salvageable.
              We have a 750ti here with a vcore short, it does not have an external atx power connected on this model so i can only assume that it is a 75w max from the pcie slot only.
              On the 12v rail there is a dead short, almost 0 ohms, i voltage injected it to confirm and yes whatever voltage you put into it is what is being directly fed to the GPU.
              Do you think that this GPU could still be operational if i repair...
              08-13-2021, 08:24 AM
            • carlitosbala
              MS-6590 KT4 Ultra - short on vcore
              by carlitosbala
              I continue my journey trying to learn how to repair a motherboard, I still have a few after the Netvista ended up working
              I am trying to fix an MSI MS-6590 KT4 Ultra, that I discovered has a short on Vcore.
              The board turns on without issue if the cpu is not installed, but it turns off after a few seconds with the CPU on.
              After analyzing the schematics (attached) I found the vcore output in page 39 (Voltage Regulator Module) is shorted to ground. I took every component referred to in that page out of the board for testing and they are all...
              03-22-2021, 09:40 PM
