Lenovo G405 Low Amp
  • joelz
    • Aug 2013
    • 18
    • jakarta
    Lenovo G405 Low Amp
    Hi all of you here, i have problem with this laptop. power on after 5sec off again. i check power on with regulated Dc power supply, the problem is there when power on the laptop only has 0.012amp with 20v set up dc. is it power vcore ic problem or somethink else, need you guide all for this problem. thanks
  • lucaszmn
    by lucaszmn
    Problem:
    Initial Findings:
    • I concluded that the
    08-12-2025, 03:01 PM
  • s_specialist
    Lenovo E15 Gen 2 GE4B0 GE5B0 NM-D011 Rev 1.0 sometimes not opening problem
    by s_specialist
    Recently, I have started to encounter a problem with Lenovo E15 Gen 2 models not opening. When you try to open the device, it gives a warning sound and does not display an image, when you apply light pressure on the keyboard, the image appears and works for a while, when you turn it off and on, the same thing happens again. Bios was tried, RAM slots were cleaned and soldered to the legs, the problem still persists. There seems to be a problem with the onboard processors, but since Lenovos glue the processor firmly from the sides, the paths are very damaged when removing it. Has anyone encountered...
    07-07-2025, 11:47 AM
  • perzyk23
    Lenovo T580 - LCD Panel problem - error 0288
    by perzyk23
    Good morning,
    I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
    10-25-2024, 12:42 AM
  • c.daniel
    Lenovo V310-15IKB weird bios problem...
    by c.daniel
    Lenovo V310-15IKB Type 80T3 laptop, i7 7th cpu with dedicated Ati video
    sn LR09493E
    MB DAOLV6MB6F0 REV. F
    The laptop was working fine, the only problem was that when I turned it on, the screen was hard to turn on, it would wait for about 30-40 seconds before an image appeared on the screen.
    Initially, I updated from windows to Intel Management Engine 11.8 Firmware, restarted, everything was fine.
    Then I updated the bios, also from windows, to the last vs, vs 46. It restarted, those lines with bios update progress appeared, restarted and that's it, since then...
    08-22-2025, 05:39 AM
  • madrali
    lenovo e15 gen2 bios ? problem
    by madrali
    Model: Lenovo ThinkPad E15 Gen 2 (Intel)
    20TD-50S0KU00
    Hi, my laptop suddenly shut down while it was running. When I try to turn it back on, the screen stays black and it emits a melodic beep.
    I used Lenovo's SmartBeep decoder and it returned error 0284:
    "TCG-compliant functionality-related error (possibly BIOS code validation failure)"
    I then tried to enter crisis BIOS recovery mode by pressing Fn + R at boot. The melodic error code changes, but nothing else happens regardless of whether a USB is inserted. I receive another...
    06-16-2025, 12:06 PM
