Laptop charging
  • Jane
    • Aug 2010
    • 188
    Laptop charging
    When I charge a laptop, the voltage is coming
    through this path:
    mains charger --> the laptop charger circuit --> battery.
    A question is: How to find out that the reason for NOT charging is the laptop charge circuit fault.( battery is OK, charger also tested). How to repair it?
    What steps to take ?
    I think that a similar voltage path , the same principles, are the same for various devices including cell phones.
    From my experience regarding cell phones , I had mobile that indicated charging, yet not charging the battery in fact( only pretending charging).
    How can it be then?
  • gabiz_ro
    • Mar 2011
    • 167
    Re: Laptop charging
    In most laptops is like that.
    Charger go to
    - power switch
    -charging part
    Power switch is like its name,give power to laptop from battery or charger.
    Charging part just charge battery.
    For charger use some conditions must be OK
    In some cases is AC_Detect or Chg_detect or present or OK
    Name on schematic depends by manufacturer.
    Also voltage must be OK,same naming style.
    For all this EC is responsible.
    So Even charger is OK (tested on other laptop) some defective parts may give problems.If reguired signals that charger is connected and voltage is in range are not OK then EC will not switch to charger and enable charger circuit.
    If laptop power up an works from charger,then problem is in charging part or battery.
    If laptop doesn't power from charger,some protection circuit (over voltage or under voltage) may be defective or EC doesn't detect charger connected or voltage OK as result no battery charge and power source is battery (on power switch)
    Most of charger IC talk with battery via SMBUS protocol.If battery not OK will not charge.
    Also in charger-battery section,on some models exists one or two signals,one is for battery detect (system,detect if battery connected) the other one is system present (battery detect that is connected)
    As for phones,break solder joint on micro USB socket on VBus pin.
    Still make some contact,phone detect some voltage,even 5V in some cases,and enable charging.As current increase,broken solder have some ohm resistance,charger IC is unable to charge,even battery percentage decrease,not increase like usual.
    Is like ( for a working fine phone ) cutting VBus in cable and inserting in series some 50-100 ohm resistor.
    Will detect charger and say charging but cannot charge in that case.
    • jasko_jacker
      • Oct 2014
      • 1137
      • italy
      Re: Laptop charging
      if the battery LED does not light and we are sure that the adapter and the battery are functioning then there are probably problems with the charging circuit. This does not mean that you have to definitely change the chip, there are other components that can cause this problem, and must be verified with the tester and the circuit diagram.
      • serious_electron
        Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
        by serious_electron
        Hello Everyone!
        I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
        06-28-2025, 02:57 PM
        NVDC charger configuration...
        11-05-2024, 03:28 PM
      • flat-earther
        how to prevent a connected charger from draining battery when not charging?
        by flat-earther
        I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
        So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
        but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
        So the battery is backfeeding the charger and being drained.
        How can I prevent...
        08-07-2025, 01:04 PM
        Bauer tool battery pack charging with a HERCULES charger modification
        The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
        Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
        05-06-2023, 12:17 PM
      • rutgerv
        Acer Swift 3 SF314-42 not powering up
        by rutgerv
        Dear all,
        For a friend I'm trying to repair an Acer Swift 3 laptop (SF314-42). I'm not a professional, but have some experience (both as amateur and professional) in working with electronic design and repair of musical instruments.
        The issue with the Acer laptop is the following:
        It was bought new and used (not heavily) at home for about three years. After normal use, it was put to sleep, connected to charger and left over night (just like any other day). The next morning, the laptop would not wake up from sleep. Instead, when pressing the power button, the power...
        08-02-2024, 06:59 AM
