I am having Chip Erase problem on TL866CS. It show overcurrent protection when i am flashing a 1.8V chip. Thereafter it is not erasing any chip and when it finishing programming it shows a error message and it says programming stopped. i tried more than 15 chips all are same message. Earlier it has problem with 25Q32 series chips, but now it show in all chips. Any person can help me.
Erasing Problem on TL866CS
Re: Erasing Problem on TL866CS
I believe you need an adapter for 1.8v chips.
https://www.aliexpress.com/item/1-8V...583185595.html -
No the problem is it is not working on 3v chips. i have 1.8v chip adapter. one day i forgot to use it for 1.8v chip. thereafter this programmer doing this problem.Comment
by ugamazingI'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
by sdi2001Hi,
on eBay I bought two chips for my HP Motherboard to replace the bios due to unknown password protection.
after resoldering both chips everything works fine but start up is slow because after 30s after pressing power on button I am getting the above mentioned bios error.
I can confirm it with OK and then the laptop is booting totally normal into his OS
how can I get rid of this error.
I saw post like this but i am a bit lost what I shall do with this program
https://www.badcaps.net/forum/troubleshooting-hardware-...-
Channel: BIOS Requests ONLY!
by theone111I have an LG Plasma TV 60PM6700 for the past ~12 years.
In the last ~3-4 months I have been having some issues.- Problem: It started with random picture disappearing (sound still worked).
Solution: Had to turn off TV wait a few seconds before turning it on again. - Problem: Then it got worse and the TV started to shut down and when turning on the no picture just sound.
Solution: Had to turn off TV wait about 10-20 seconds and turn it on again to solve. - Problem: TV shuts down
1 Photo - Problem: It started with random picture disappearing (sound still worked).
by testaccgtaHi, everyone!
I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...-
by Zeonalbastai have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double... - Loading...
